Sarchi
- Jan 15, 2007
I disagree. There's a big difference between playing loud, and recreating a bass-driven scene like a dance club. I've owned (and built) many tube amps, from 3-watt 2A3's to the massive Altec 811 monoblocks of the 60's. And I've had speakers of average sensitivity all the way to 100+dB. It takes a massive amount of current for (as an example) Bob Marley to sound 'right' from speakers in home, and I haven't found tube amps up to that task. Except for some big Atma-sphere otl's, those are the only ones that come to mind. As I said, this is an unnatural thing anyway....it doesn't detract in any way from a tube amp's ability to do what it does do, well.
I hope that is helpful to the OP.
Originally Posted by Fing /img/forum/go_quote.gif I hear people overcome the speaker problem by using more sensitive speakers. Most high efficiency speakers are rated at greater than 90db+ per watt at 1 metre. Of course, it does depend on the quality of that watt or watts. A lot of solid state watt is wasted on feedback and ensuring that it remains relatively free of distortions. Since tubes can handle distortion in a harmonic manner, they can be implemented in a feedback free manner. I'm not too hot on the electronic side of things All I know is that my 300B amp sounds fantastic and will blow the drivers out of my Monitor Audio speakers if I really cranked them up. |
