"On pre-order list and waiting since 1/3/2011. Doing my reading, looking for Woo Amp users. I see you use the LCD with WA6SE, that is the amp I have.
In your sig it now shows Balanced cable for LCDs. Does that mean you now use the LCD with the Roc and not with 6SE anymore?"
I am using the LCD's with the Roc more at the moment because I just received my balanced TWAG cable. Trying to burn in the cable and get used to the differences. I have only briefly listened on the Woo since I got the cable. The Woo still sounds excellent with the LCD's and will probably sound better than I remember with the new cable even without being balanced.
"If so, can you compare bal vs unbal with LCD?"
Its difficult to compare balanced vs unbalanced in my system because it would mean either using different amps or just using the Roc when in SE mode only half the amp is being used so its just like using two different amps again. I can say say that using the Roc/TWAG balanced leads to more dynamic,detailed,cleaner,defined sound with more prominent hf's (although I have never considered the LCD's as 'dark' sounding). But that is just as much as a comparison of the Roc single ended vs balanced. The Woo6se is better than the Roc single ended although the differences are very slight using easy to drive phones like my ALO-780's.
"I am really concerned over not have balanced Amp. I have Audio-GD NFB2 (kind of balanced, if using Audio-gd amp and cables) and use RSA Nighthawk with my TT which can be considered balanced, but everything terminates to SE on Amp."
The NFB-2 as no balanced output so I don't understand when you say 'kind of balanced'. Yes a balanced Audio-gd amp will balance the signal but I would expect the Roc/Pheonix to sound better when used with a proper balanced source.
"I am assuming there is no way to open WA6SE and rewire for balanced, right?"
No!
"The balanced sound is growing on me now that I wired my UE TF 10s to balanced with Null Audio Enyo and HiRose 6 pin to iBasso PB1 Toucan. The headstage is significantly better than TRS sound. I love my WA6SE (with Sophia of course) and do not like the thought of going with Audio-gd balanced setup as I am not that happy with my NFB2 sound. I bought because I like the Wolfson DAC voicing but am not impressed when A/B same songs (flac or 256K MP3) with same in vinyl (ProJect rm6sb and Denon103 and AT33EV cart)."
If its balanced route you want to go down then you will need to change your DAC. There are some tube based DAC's that sound more like vinyl but most are not balanced. The Audio-gd Ref series dac's are supposed to sound abit like vinyl so maybe the Ref 5/7 if in budget.
"So I would like to plan now, before the LCD2 arrive to get my setup in good shape. I know it is subject to ones personal taste, but in your opinion(s) is balanced going to open the head stage and placement that the LCD2 lack, and if it is perceivable, what would you recommend in DAC/AMP considering I have no fear in selling off NFB2 or WA6SE to achieve better sound (I'll sell my D7000 and HM601 to raise cash if needed). I am sincerely concerned on the issue of balanced output and even if the source is not truly balanced (2 PS, full mono, separate path all the way) but shares PS or OTL than I am OK as long as it opens up the sound. It is sad that I now like the experience of my portable rig costing under $900 to my desktop rig costing almost five times that. If I add the LCD2 to existing rig and still prefer the head stage and placement, I will scream out in anguish (I know, kind of dramatic) but it's true. The SQ of the TF10s is not better, but the staging certainly is."
If you want a very wide and deep soundstage then maybe you have picked the wrong phone in the LCD's. The soundstage is never going to reach HD800 or T1 width or depth (although I have not heard the HD800's), but for me thats not a problem. I would prefer a more closed in soundstage rather than one that makes performers sound as though they are playing on different
continents!
If you have no problems selling of your woo/nfb/d7000/hm601 then maybe the Woo22 with a balanced dac would be a good choice.
Good luck
