Guys, here is the fixed adapter that you can use two 6BL7 per channel....I do not own this adapter, but i think you can rotate it a little by loosening the middle screw, like what has already been mentioned. You may be able to use two 6080 tubes in this adapter , if your amp can handle it, but I will not swear to it as I am not sure if they will fit.....gibosi will probably know, as he owns this adapter.
http://www.ebay.com/itm/1pc-Dual-Gold-plated-6BL7-TO-6AS7-tube-converter-adapter-Fixed-octal-version-/191850787735?hash=item2cab32b397:g:LfcAAOSwiYFXFE3J
Here is the adapter to run three 6BL7 per channel, it is
not fixed....it can be rotated, but not a huge amount, it also has a screw in the middle of the adapter, but I ruined one adapter for dual EL3N tubes, that was made identical to these adapters, messing with the screw, damn small screw and very tight.
You can also use two 6AS7G or two 6080 tubes per channel with this adapter if your amp can handle it.....if you are only going to use two 6BL7 per channel, I am thinking the fixed adapter is the better option.
http://www.ebay.com/itm/1pc-Gold-plated-tube-converter-adapter-for-3-6BL7-instead-6AS7-6080-/201533519050?var=&hash=item2eec5574cam7QIJQoBJj_pyPJbIpmgyQg
Hope this helps with some of the adapter questions.
