Thanks for the detailed reply. And of course, being the owner I will go with it being a WE421A
. Having said that, I will be sending this tube for testing in the next couple of months. And I am going to ask my tester if the transconductance can be measured (on paper WE 421A has 20,000 uMhos, and 5998 has 14,000 uMhos). My tester has the AVO MK IV Valve Characteristic Tester, and AVO VCM 163. So am hoping it can be measured. Results could answer the speculation! The tube was bought as testing at NOS levels.
I have been in touch with the chap who tests my tubes regarding the above, and have been enlightened by his response, or should I say, has proved my ignorance
. His response is below. As it turns out I have been getting these results anyway (expressed differently) on previous 5998/421a tubes I have sent for testing. I have included a pic of a 421a I had tested a long time ago, obviously low testing, but doing great service in my Bottlehead Crack. 3rd tube down.
So, for those following this little saga! I will be sending the early 1957 “Chatham Electronics/IBM 2399 clear top, rectangular Mica supports, bottom D getters,” which is identical to early WE421A’s, for testing. 1st tube down.
It just so happens that I have another, this one 1958, “Chatham Electronics/IBM 2399, but chrome top, with the more conventional oval mica supports,” which is identical to Tungsol 5998 which will also be sent for testing. 2nd tube down.
I bought these tubes as being tested at 62/64 and 63/64 where 40/40 was minimum good. So this little escapade might prove conclusively that the early clear top rectangular mica 2399 is indeed the same as a 421A. But then again, it could end up proving nothing, which may well be the outcome! But still fun to see!
“regarding the transconductance measurement of the 5998 and 421As it is the same as the TC measurement I give you, but expressed in different units so uMhos (ohms spelt backwards), is the old imperial way of measurement and found in a lot of old valve data sheets, the SI unit is Siemens. A very simple way of converting is just knocking off the decimal points so 14,000 uMhos is TC 14.0 and 20,000 is TC 20.0 etc.”
