RPGWiZaRD
- Jan 31, 2010
Just go to file -> preferences -> playback -> dsp manager and select "Default: Stock foobar" for default foobar2000 settings in the dropdown box "DSP Chain presets" and click load and then "Default: Balanced (forward)" for the Dolby headphone config. I keep checking between stock and modded settings quite regularly and this way you can quickly switch on/off to instantly hear the difference, this is the easiest/fastest way.
But yea use the "DSP Chain presets" to store your configs, this saves the settings also for every plugin.
Yes RPGWizard,thank you for the support.I assume so that with with windows sound standard processing it resample it automatically whether with wasapi it does not ,at the moment.
Right now i am testing 96/24 and 48/24 both 5.1 and your version plays both correctly ,where on the other foobar it still unable.Ok because i still using your foobar version (even i use mostly flat equalization) since you posted on head-fi,as it sound fine with everything.I just was wondering in having a single Foobar where i could chose quickly between various playback methods without having three types of portable Foobar on my desktop.Guess i have to still researching ,or at least gain a little more knowledge about it.Salute
