RPGWiZaRD
- Jan 31, 2010
Doesn't need updating as it's still using the same settings as last time. All files which needs updating are always updated, no need to remind me. ;P The links I post on the last page I always copy from the first page.
Ahh ok, I see the filename is still 1.1.6 on the fbcp files but it doesn't really matter as it's using the same settings as previous config anyway that was using foobar2000 1.1.6, so ignore the filename, no update needed on the fbcp files, I should just remove the foobar2000 version from those files as it doesn't really matter what version it's based on, it's just saved plugin configs for foobar2000.
Wizard, please update Manual install fbcp fileThank you for your work!!!
