LCMusicLover
None.Which software do you all use to EQ ...?
Which leaves me with four new lines of investigation:...
ULZ - Pontus: Least favorite. Best for Jethro Tull ‘Benefit’. Noticeable reduction of highs, high hats lost in guitar
USD - Pontus: Second best. Nearly as airy as USD/Gumby. Less detail.
ULZ - Gumby: Tied for best. Treble reduction less significant but still present. Full sound, feels like pushes more air.
USD - Gumby: Tied for best. Brighter, airier, more detailed. Also less weighty. Only combo to sound even a little ‘sharp’
I hear some noises when laying down if the cans aren't perfectly positioned and they're not just resting without strain. What I hear is different than the headband flex. When I first heard it I was scared that I was hearing the pre-failure 'driver crackling'. But by adjusting Utopia on my head the sound went away. No way to know if this is the same thing you're hearing.Here's one for you guys: do you ever notice very slight or subtle ticks or clicks when listening that aren't in the music? Occasionally I get this and because I am quite sensitive to these hearing things I more often than not rewind just to double check if it was in there, and I have theorised that it is - if not in the music itself - the result of the headphone physically, such as the pads expanding or air escaping. I also get it with my Clear.
Just me? Am I losing the plot?
Which software do you all use to EQ, and how can you do that whilst preserving bit-perfect playback via ASIO or WASAPI?
Equalizer APO, though I don't know if it supports asio or wasapi. It's not the best but at least it's free. I think DMG Equilibrium is highly recommended but not cheap, you can try that.
If you hear clicks and pops on multiple headphones, then it's not the headphones. Though if they're there on the original recording but are very faint, many headphones won't reproduce them as audibly, but on something like the Utopia that resolves well, they'll be very apparent. It could also be something else in your system of course - try another source and see if you still hear it.
IMHO There will be times the hekse will be the more preferred choice (eg when you want a break from the utopias and/or you need the hp to be a little more forgiving). I happily have both.My first post here and just want to find out how differ was your impression of FU after 100-150 hours of burn-in? Is it my brain or the headphones? I remember how claustrophobic and oppressive Utopias did sound to me at first, now the sound is much more open and basically no fatiguing at all. Also I wonder if there are any better cans for rock/indie/post-punk/newwave/alternative music. I've just received hifiman 1000se(not new) and after 2 days with them I've got the impression that Focal's sound is so much fuller and it allows me to engage in music to a much greater extent. Perhaps my amp (feliks eufhoria) is to "blame"...
Very well said.IMHO There will be times the hekse will be the more preferred choice (eg when you want a break from the utopias and/or you need the hp to be a little more forgiving). I happily have both.
The warmest the hekse sound to me is after coming off a spell with the utopias. But I don’t consider them warm.
I consider the utopias having fantastic detail and instrument placement and the hekse having great detail and placement but the hekse are wider in soundstage and there is some magic in that regard
Imho both are great.
The hekse a bit more of an all rounder due to them being a little forgiving
ymmv
