Justin_Time
Oh man, what an improvement. If Focal provides this as stock accessory, could we ask for a discount?
Unfortunately, I only have Stax's own amps with my 007-Mk1. I heard the 009, which is superior in every way to the 007 except for the bass.If you are looking for perfect bass nothing bests the sr-007mk1. It needs a well built powerful energizer behind it but yeah your not going to get any better. It has other shortcomings though. A lack of air for instance.
The only time I ever had any trouble with Utopia's bass being loose was when the amps impedance was too high, like with the HDVA600. IMO, Ragnarok>Yuggdrasil delivers clean tight bass when paired with Utopia.Unfortunately, I only have Stax's own amps with my 007-Mk1. I heard the 009, which is superior in every way to the 007 except for the bass.
I really need a killer SS amp--the GS-X Mk2 does not quite do the job--and balanced silver/litz cable to tighten up the bass of the Utopia just a tad. Any recommendation?
It is a long story. I am not sure it is worth explaining but here it is in a nutshell.Wait...I am a bit confused. Can you please elaborate with much more details than just this ?
1. I was quibbling about the bass on the Utopia having just a tad too much bloom-a slow decay and was wishing for the perfect amp for it.
2. It was suggested that the Stax 007 Mk1 has a really tight bass with the right amp.
3. I responded that the only amp I have with the 007 is Stax’s own amp
4. Finally I switched the topic back to the initial question: is there a perfect amp for the Utopia bass?
Actually, after a few hours listening to my own amps. I may have found a...partial answer.
The GS-X Mk2 is a great amp for the Utopia overall, but in the bass, and in the bass alone, the Vioelectric V281 has a clear edge: tight with plenty of slam and no upper bass overhang. Unfortunately, the faster decay with the V281 makes it less ideal in other areas. Overall:
GS-X Mk2: smooth midrange, good depth and sweet, delicate treble. Bass: great impact but just a tad too much bloom
V281: tigh focus, up-close, intimate midrange and tight bass with control and great slam. Traces of edginess in the treble.
The difference was almost like that between tube and solid-state sound but to a far, far smaller degree. I am talking about two great amps with great sound and just minor shortcomings when paired with the Utopia. The GS-X in the bass and the 281 in the treble.
Do you find that any of your sources help/hurt either of the Utopia/amp pairings? I’ve found some of the same treble edginess with my V280. I hoped that the Bryson BHA-1 might be better, but I’m actually preferring the Violectric, although the difference is very small. My Pontus helps a little vs Sonica DAC.
that's also been my experienceThe only time I ever had any trouble with Utopia's bass being loose was when the amps impedance was too high, like with the HDVA600. IMO, Ragnarok>Yuggdrasil delivers clean tight bass when paired with Utopia.
i didn't think that the sr-007's bass was anything special tho i liked the headphone overall. i thought that the the LCD-4 out-performed it in that department in a direct comparison. its bass presentation was better defined to my ears.Unfortunately, I only have Stax's own amps with my 007-Mk1. I heard the 009, which is superior in every way to the 007 except for the bass.
...I had the Bryston for several months. If you want less edginess, that is not the way to go.
