one would hope so... i have no desire to tamper with my utopia and that includes "pad rolling".
Agreed. Also why I don't "cable" roll. I think it's just silly that people think they can make something better than those that designed it.
OK, I was being a bit snarky there. Pads make much more of a difference than cables, and sound is all about what the listener likes. Sure, there are measurements to achieve a certain frequency response, but it still comes down to "if it sounds good to you, then it's better (for you)".
Amps, DACs, cables, pads, EQ, tone controls, power conditioners, magic pebbles. It it makes it sound better to you, then you feel happier. Happy is good.
If someone doesn't want to try something different, no problem. No reason to poop on others that want to try different things. If you've tried different pads, like some have, and you prefer the stock pads, that's great and we all would like to hear about that. If someone has never ride alternatives, I'm not sure say one will not try adds much to conversations.
Not trying to be mean here; I'm just saying let's try to keep the signal to noise ratio a little higher.
