joshnor713
You know the Utopia's impedance is only 80 ohms? Practically anything can drive it, there's no "need" for a more powerful amp.... wanted to know if i need to get external amp to drive utopia..
No they clip on the same song with my A&K Kaan Max as well on high gain at about volume 113 / 150
I think now to make sure it will be nice if you can get a dB meter or use a similar app from your phone (less accurate result though) and try to measure the sound pressure level from your Utopia at the point where you find it clips. Try to position the dB meter or your phone's mic at the inner cavity of the earpad.
I can tell you that the euforia evo sounds 100x better than the utopias out of my a&k… not even comparable…You know the Utopia's impedance is only 80 ohms? Practically anything can drive it, there's no "need" for a more powerful amp.
....and again this has nothing to do with the power, your A&K is more powerful than the Euforia. And the Utopias are not easy to drive because of the 80 Ohms, but because its high sensitivity at 104dB SPL/1mW. The Utopias and in general dynamic driver headphones seems to be preferred on tubes and the Euforia is one of the top options out there.I can tell you that the euforia evo sounds 100x better than the utopias out of my a&k… not even comparable…
Wow only 100x.....seems not worth itI can tell you that the euforia evo sounds 100x better than the utopias out of my a&k… not even comparable…
Sorry. I didn't get it... why the Utopias are supposed to distort on tube amps? In which tube amp did you notice it?.That's why my Utopia/Nutopia distorts for example on Gladys Knight's License to kill in the low end or on many other tracks if i drive it with a tube amp
But that's just my humble opinion about the French with an Tube Amp
deal!I'd rather spare us that...but I can show you and let you listen to it when you're at the High End in Munich
NOMAX
PS.lol
Mine aren't mildly clipping, they sound like rattling plastic on this song - https://tidal.com/browse/track/87563344Can confirm my Utopia's have always mildly audibly clipped before getting "really loud" on my EC ZD. It doesn't happen on my GSXmk2, Mojo 2, various mobile devices. I had shrugged and chalked it up to the ZD's higher output impedance of the 6c33-b tubes, but that was just a really non-informed guess.
edit: the ZD hasn't produced clipping distortion with any other headphone that I've tried on it even to the point where the SPL becomes painful; the phenomena for me so far has been isolated to the Utopia's.
I was curious what all that clipping discussion was about (I'm a 95% classical and Jazz listener, I've really never experienced it in my year of owning the 2020 Utopia).Mine aren't mildly clipping, they sound like rattling plastic on this song - https://tidal.com/browse/track/87563344
