jlbrach
- Jun 4, 2005
actually not probably...people are getting murdered by inflationProbably because for the majority of people, their annual salary raises aren't matching inflation lolol
1.5% raise vs 15 to 20% INFLATION..MINIMUM...????actually not probably...people are getting murdered by inflation
Agreed. I’d like to see more companies offer upgrade programs for their flagships like Audeze because it’s hard to run out and spend $5,000 on any headphone, and more so, if you already own the Utopia. Upgrade programs might be the best way to maintain customer loyalty and drive flagship product sales in a recession. I can’t imagine many Utopia 2020 owners who paid MSRP buying the latest 2022 offering.to be honest I see nothing in the description to make me run out and drop 5k...I will listen to opinions and reviews
Not at all. Based on what I’m reading about the new Utopia’s it sounds more like a tweak than something brand new. People with OG Utopia’s should be okay with this news.i don't see utopia being classed as "outdated" or anything any time soon, at least for me
Thanks for the reference! Also, thanks for alerting me to this thread, I didn't realize the Utopias were getting a refresh, it's been interesting to read the last several pages.The voice coil is the bit here:
The redish ring bit above.
... and the copper ring bit above.
My guess is that they've redesigned it so it's better attached rather than with a thin wiring that's prone to snapping:
Pic above from @LuthierJeff's thread with his adventures fixing his Elex - https://www.head-fi.org/threads/fixing-broken-massdrop-x-focal-elex-headphones.963510/
Hi there, that was a good post. It's interesting, I've always imagined the engineering constraints largely going in the opposite direction from what you said. I should say I can't make much comparison from experience, as I've never had a nice loudspeaker setup at home, nor am I an engineer, but part of what attracts me to headphones is seemingly fewer obstacles and constraints to overcome. For example, the room/earcup is always controlled and predictable. Also, since the volume of sound is so much more dramatically low than loudspeakers, they can use a single light weight driver to cover the whole frequency range without the need to develop crossovers, deal with multiple driver placement and phase issues, worry about amplifier headroom as much, stuff like that. Of course, what you said makes a lot of sense as well, so I wonder if it's a matter of apple and oranges just having different constraints. I would imagine that a truly top-end speaker setup would totally out-perform a top end headphone setup, but maybe someday I'll get to compare those things.That seems odd. Generally the fewer engineering constraints the better the sound. For instance open back headphones remove one big engineering constraint and thus sound improves measurably.
However headphones still have some big constraints. Geometry and driver size. Speakers eliminate these constraints, or at least expand them hugely, so from an engineering perspective you can do a lot more. I'm not doubting your experience, but generally people will prefer the sound from speakers for these reasons, in a well treated room anyway.
Any headphone will eventually clip. In 4 years of ownership, I’ve never experienced clipping, even when listening to bass heavy music at high (but not deafness inducing) volume
The fact that people are posting certain examples that need to be played back beyond reasonable listening levels doesn’t indicate (to me) a design flaw
I’m sure that if you play a constant 24hz wave and keep turning up the volume, the new Utopia will eventually clip or bottom out the driver. Since that isn’t part of my evaluation or day to day listening, it doesn’t concer me.
The "clip" / rattle sound is really different actually, compared to what amp may cause (when under powered).What shouldn't be forgotten with clipping is the effect that DC offset from the amp would have. It would only take a few mV to cut headroom in one excursion direction by tens of decibels. Would dramatically change the volume at which clipping becomes apparent.
Excatly. Lots of folks listen stuff with no bass whatsoever or never watch a movie. they never gonna notice the problem with jazz or classic.Like I wrote above, Stellia has no problem. So not that all focal behave the same, and I never tried any Utopia from 2021 production (or newer, so can't confirm).
No you don't need 24hz wave to create the rattle, that's why many people reported the problem in various focal threads (not only utopia). Basically need a song with strong sub bass response.
My understanding is that Focal closed-backs (Stellia, Radiance, Celestee, and Elegia) can take advantage of a bass reflex configuration / system with the little vent/port like with some speakers to reduce driver excursion. With that, they also use a shorter voice-coil so less likely to run into the clipping issues as seen with Focal's open-backs like the Utopia.Like I wrote above, Stellia has no problem. So not that all focal behave the same, and I never tried any Utopia from 2021 production (or newer, so can't confirm).
