r343
- Nov 29, 2016
Utopia sounds good even in low volume listening ~60dB or below, full, dynamic and nothing is missing. Many headphones are just crap with low volume, usually dynamics flat out first.
It'll be different for sure. Abyss take on sound is pretty amazing.Diana TC.
Just wondering if it s an upgrade over my beloved utopia..
I own both. In my opinion, if you have the gear to power the Diana TC then yes absolutely. The DTC sounds wider more open, has better clarity and more resolving. The Utopia’s advantage is it’s efficiency.Diana TC.
I have a susy dynalo and hugo.I own both. In my opinion, if you have the gear to power the Diana TC then yes absolutely. The DTC sounds wider more open, has better clarity and more resolving. The Utopia’s advantage is it’s efficiency.
Diana TC.
i've not auditioned the diana phi or the new diana tc, which probably makes this post irrelevant but i have tried the original diana and diana v2. i compared both directly to the utopia. i recall the v2 surpassing the utopia for clarity and matching it for detail retrieval. however, the utopia sounded fuller. i would lurv to try the diana tc, particularly if abyss has now improved its comfort as i am a fan of its compact design, lighter weight, build quality and sound signature.I own both. In my opinion, if you have the gear to power the Diana TC then yes absolutely. The DTC sounds wider more open, has better clarity and more resolving. The Utopia’s advantage is it’s efficiency.
Which Diana? As I reckon, all of them have different impedance rating.Wait, all the dianas have pretty much the same efficiency and resistance of he1000v2. I owned the hifiman, yes it sound from the hugo but we are far from their potential.
I also found they sounded best plugged to the speaker tap (of the burmester..)
Generally speaking I think the Utopia plays well with most amps, period. I think most owners will agree with that and that’s one of the Utopia‘a key strengths. One of my favorite pairings was with the feliks euforia. Just fantastic. Oddly and maybe because I have other headphones that pair better with my WA33, the utopia don’t sound as good, as I remember them with other pairings.For those of you that have the Utopia how is they synergy with tube amps? I have a WA5 LE V2 and I’m more than curious how the Utopias would sound with that.
