NeoDiNardo
- Jul 18, 2011
It’s on the short list of things to hear.
Have you won the jackpot? I hope you have enough time to listen to music, tooI know I’m keeping the Stellia for closed-back headphone needs, I know I’m doing Noble CIEMs as I wanted a Wizard Edition for like forever for ultra portable needs, and I just need one or two open-back headphones to seal the deal. Perhaps the Utopia and one other. And perhaps the Sony flagship cans just to see. Susvara, Final, ETC, there are just so many to choose from.
In your position, it’s definitely blessing to be in this planning stage. Hope you appreciate the journey every step of the wayLong-term plans. The only other thing I’m getting at the moment is perhaps the nobles.
May I suggest the Meze Empyrean as a contrast to the Stellias. Well thought of in many quarters.....
Wow, you're going straight to top of best sounding gear out at the moment. My path was a lot slower getting there, but it allowed me to find some mid-fi gems. I'm thinking about the Stellia's or repurchasing the Utopia's again. I have the Audeze LCD-XC's, Sony Z1R's, and Audio-Technica ATH-AWKT's as notable closed headphones. The surprise of the group is the AWKT's. They are wonderfully detailed, neutral, spacious with a balanced attack. The Stellia's, I would assume would improve on this with a better bass response.Exactly the path I’ve taken.
Stellia
Utopia
Empyrean
I’m now thinking HE1000SE, Susvara, or Aeolus+Arya for similar spend.
As I read that graph it seems that the Utopia pads lowers the bass quite much and at the same time pushes the mids way too much. I don’t know. Doesn’t look that interesting to me. But someone else might like itDoes anybody know how the Stellia sound changes when using the utopia pads with it? There is a very interesting article on the frequency graph changes here:
https://forum.headphones.com/t/focal-pad-rolling-experiments-measurements/2822
It seems the utopia pads change the sound in the lowest end of the spectrum. Can anybody confirm this, and what real-life effect this has? Reason for the swap would be the plusher, more comfy feel of the utopia pads .
For those trying to find this: adding the artist's last name (Aboulouafa) helps to find this song. I could not find it without.I found this amazing track on Qobuz by an artist named Meryem called THE FRIEND. The sound staging is surreal on my Stellias, especially when percussion comes in about 1/4 the way through the song. Yet another example of the sound quality these headphones can offer.
Yes,but make sure to burn-in first,min 200 hours before critical listening,you will be satisfied with arctic cables signum+ series silver cable,but if really want high end then try the palladium seriesI have an issue with the Stellia. I don’t like the bass as it sounds not coherent, it is not a full bass. Also I found the mids a bit recessed as I was turning up the volume to get the vocal clearer.
Can a high-end cable address these things? And how sensitive is the Stellia to high-end cables?
I can only confirm @Asdcreation ´s post! I have both signum+ and the palladium cable from Arctic Cables. If you just want more bass and clearer mids, grab the signum+, if you also want to bring out all the highs with a great extension, then you'd have to save up for the palladium cable. The signum+ is more of a analogue sound, the palladium is leaning on the reference side.Yes,but make sure to burn-in first,min 200 hours before critical listening,you will be satisfied with arctic cables signum+ series silver cable,but if really want high end then try the palladium series
