Unfortunately, DanaCable expressed some minor reservations on soldering their very big Lazuli Reference headphone cables onto the much smaller 4.4mm Pentagon connectors. They recommend staying 4-pin XLR and using 4-pin XLR to 4.4mm Pentagon adapters, especially when considering resale options. I expect that to be the answer for most cable makers relying on soldered connections. Or I’d be advised to buy Woo Audio’s 4-pin XLR female to 4.4mm Pentagon male adapter bullet. And have that big thing stick out on top of my FPGT?? Not likely. I suppose I could then buy a 30cm 4.4mm Pentagon extension cord to separate that adapter from my FPGT, this does nothing for the big adapter’s weight however.
Interestingly, Kimber Kable Axios headphone cables uses hollowed out wood shells filled with a solid resin seal to aid in just that kind of task. The Kimber Kable Axios rep said it took them awhile to figure it all out but now their 4.4mm Pentagon connections are super solid. However, I read in a comparison that the Lazuli Reference sounds a fair amount better than the Axios Copper with the Focal Utopia. Decidedly, even if I get the DanaCable Lazuli Reference headphone cable with 4-Pin XLR, I think I’d want to use it with a 30cm Kimber Kable Axios 4-pin XLR to 4.4 Pentagon cable adaptor cable. With that resin sealing technique I believe Kimber has all my 4.4 Pentagon connection / adapter business for now.
The big question is should I purchase a Lazuli Reference for better sound and use an Axios 4.4mm Pentagon adapter cable, or just go all Axios? And if I go all Axios I could do 4.4mm Pentagon all the way to the 4-pin XLR stereo rack end point, using 4.4mm Pentagon extenders for less connector weight and using the first part of the 4.4mm Pentagon cable with portable gear like the Lotoo Paw Gold Touch.
