Rob80b
Also I have a question, if you purchase a used “for parts” Focal Clear on eBay and transfer the drivers assembly of the Elegia, to the Clear, will it sound like the Clear or are the drivers of the Elegia physically tuned differently?
Has been discussed previously.......
As noted earlierConvert Elegias to Open?
Anyone heard of modding the Elegia to open (i.e. to try to make them into Clears)?
In my opinion, this is a recipe for disaster. So much care went into the dampening inside the Elegia earcups, it is often compared to miniature room treatment. Converting it to open back would literally remove these headphones greatest feature
Drivers are different.......This is not 100% with any surety, but I think that the driver is the same as the OG Clear, and you could (in theory) use it as such.
Ditto.
As per....
https://www.focal.com/sites/www.focal.fr/files/shared/catalog/document/stellia-elegia_whitepaper.pdf
"A speaker driver operating in a limited inner volume environment must first and foremost have low compliance. Indeed, the surround on this type of transducer must permit excellent control of the moving part and thereby induce less elongation. The surround plays a dual role.The first is to provide the largest elongation possible, which lies at the root of the ability to reproduce the dynamic range of the original audio signal. At the same time, it is also designed to control the travel of the moving part to ensure a piston action from its lowest to its highest amplitude. Focal, therefore, decided to choose a dedicated surround, constructed in the same way as the Elear, Clear and Utopia speaker drivers. The material used is the same, but the thickness of the Stellia & Elegia transducer has changed to 110 microns. The geometry of this new half-roll NBR surround was the subject of an extremely detailed study into how to gain optimum control of the moving part, even at the lowestfrequencies and loudest volumes."
But who knows, might be worth a try.
