Focal Elegia - what do you think?
Apr 28, 2021 at 10:10 AM Post #2,686 of 4,861
#Crinnacle PEQ:
Preamp: -6.5 dB
Filter 1: ON PK Fc 286 Hz Gain -2.9 dB Q 1.23
Filter 2: ON PK Fc 1150 Hz Gain -3.2 dB Q 0.62
Filter 3: ON PK Fc 2931 Hz Gain -3.5 dB Q 3.90
Filter 4: ON PK Fc 3906 Hz Gain 4.7 dB Q 1.72
Filter 5: ON PK Fc 6006 Hz Gain 4.2 dB Q 0.96
Filter 6: ON PK Fc 18 Hz Gain 0.8 dB Q 1.72
Filter 7: ON PK Fc 5772 Hz Gain 1.2 dB Q 3.22
Filter 8: ON PK Fc 6271 Hz Gain -3.5 dB Q 7.37
Filter 9: ON PK Fc 10494 Hz Gain 2.2 dB Q 1.00
Filter 10: ON PK Fc 19658 Hz Gain -8.4 dB Q 0.40
#Reference Audio Analyzer's:
Preamp: -5.9 dB
Filter 1: ON PK Fc 50 Hz Gain 2.8 dB Q 0.31
Filter 2: ON PK Fc 376 Hz Gain -3.1 dB Q 0.32
Filter 3: ON PK Fc 3643 Hz Gain 6.3 dB Q 2.02
Filter 4: ON PK Fc 5706 Hz Gain -6.0 dB Q 3.92
Filter 5: ON PK Fc 9756 Hz Gain 3.7 dB Q 1.51
Filter 6: ON PK Fc 277 Hz Gain -1.3 dB Q 3.22
Filter 7: ON PK Fc 657 Hz Gain 1.2 dB Q 1.87
Filter 8: ON PK Fc 1908 Hz Gain -2.5 dB Q 1.77
Filter 9: ON PK Fc 2164 Hz Gain 3.7 dB Q 4.18
Filter 10: ON PK Fc 7196 Hz Gain 1.2 dB Q 5.41
Apr 28, 2021 at 7:55 PM Post #2,688 of 4,861
Try this one
Apr 29, 2021 at 3:05 AM Post #2,689 of 4,861
May 5, 2021 at 5:06 AM Post #2,691 of 4,861
#Crinnacle PEQ:
Preamp: -6.5 dB
Preamp: -5.9 dB
What are these profiles for? Is one for desktop and another for DAP?
May 5, 2021 at 8:00 AM Post #2,693 of 4,861
Well partly yes, the sound profile of Elegia is a bit weird, but it is a very capable pair of headphones, very detailed so a lil' EQ will give you incredible results. And of course, most headphones do not a flast sound signature, just because it doesn't sound particularly good..
May 5, 2021 at 10:18 AM Post #2,694 of 4,861
That would be right in most cases, since most DAPs only have fixed-band equalizers. But it would be applicable to desktop, also, if the user did not have parametric equalizer software installed. And a lot of high-end DAPs have PEQ, so the PEQ profile can be used on these, too. Depends on the equalizer you have at hand.
May 5, 2021 at 10:20 AM Post #2,695 of 4,861
May 5, 2021 at 2:25 PM Post #2,698 of 4,861
Do you use these EQ profiles? With or without the Dekoni leather pads?
May 5, 2021 at 2:32 PM Post #2,699 of 4,861
Me? No. I do have the Elegia's fitted with the Dekoni non-fenestrated sheepskin pads.
