I just stole an extra hour during my lunch break to try out the Elegia at the local shop, driven by a Sony WM1A DAP (using the single-ended output). I liked them quite a bit actually, and my TL/DR is that they're probably worth $900 if they fit your use case and prefs.
Random impressions:
- Isolation is okay but just okay.
- The light-silver and black colorway is on the tacky side IMO. The synthetic pads probably have a lot to do with that. I would want them for work so I really wish they had a more boring mono-tone look.
- The pads are way more comfortable for me than the Clear or the Utopia. Must be the material (go figure).
- The stiff-ass cable cut out a little in the left channel if I bent them in the wrong way (ie, defective). Not a great sign but oh well.
- So yea, the mids really are notably forward. More so than I remember the Clear being. I did feel they were a little shouty on first impression though. I don't want to make too much of that though, since I didn't mind after a few minutes.
- Highs are also quite forward. So as far as the detail that the headphone has to offer, it's going to give it to you.
- Bass is tight and articulate, which IMO is a signature quality of Focal cans. I usually need to juice up the bass a little on any setup (~3dB), and I did that this time as well. The bass responded well to this. I liked the tonal balance a lot more after doing this.
- Overall in terms of resolution, I thought it was quite good, coming out of the WM1A.
- Soundstage was Focal-sized, and slightly worse so for being closed. This was slightly off-putting on first impression, I can't lie, but after a few minutes, focusing on the music and the details, I actually really enjoyed the imaging.
- Instrument separation was very good, I found nothing to complain about on this.
- On several tracks, as soon as the music started, I kind-of went "Oh!", because it immediately sounded very good to me.
- I wanted to listen to them longer than the ~50 minutes I allowed myself during my lunch break, so that was of course a very good sign.
So the two biggest watchouts, I think, are the forward mids and the soundstage. I'm going to try to listen to them one more time with a Woo WA8 portable tube amp to see how that affects tonality, soundstage, and overall presentation, and if I like it more than with the WM1A, I'll probably get them for work.
