Focal Elear - Impressions Thread
Jul 13, 2017 at 10:15 PM Post #3,586 of 6,742
How do the Elear compare to the HE-500 and the Mrspeakers Aeon?
I own the HE-500 and intrigued by the Aeon. With the HE-500, I love the vocal presence and speed, but I sometimes feel I'm missing the engagement of even something like the Phillips X2.
Jul 13, 2017 at 10:21 PM Post #3,587 of 6,742
Can't compare to either, but I can tell you that there are very few headphones more engaging than the Elear.
Jul 13, 2017 at 10:38 PM Post #3,588 of 6,742
I like the Elear's over my he-560's and I do really enjoy my 560's, the Elear's have spoiled me, they are my go to hp's you'll really enjoy their sq worth checking out..
Jul 13, 2017 at 11:32 PM Post #3,589 of 6,742
From my memory, if you have the he-500, for me it's better compared to aeon that is ligthter, more comfortable and easy to drive
Jul 14, 2017 at 3:39 AM Post #3,590 of 6,742
The HE-500 is better than the Aeon?
Jul 14, 2017 at 8:24 AM Post #3,591 of 6,742
Also, comfort of the Elear has to beat the HE-500, right?
Jul 14, 2017 at 10:08 AM Post #3,593 of 6,742
I wear 7 1/4-1/2 hat, and for me, the Elear is comfortable for hours.
I have a small head. The comfort issues of the HE-500 have more to do with the weight and how poorly it's distributed on the HE-500.
Jul 14, 2017 at 11:48 AM Post #3,594 of 6,742
The weight is a non-issue for me; however, this is an issue for some. The Elear, for me, is very comfortable. Do you have access to an audio store where you could try them on? I did, so it was easy for me to actually try them, which obviously led to me buying them.
Jul 14, 2017 at 1:14 PM Post #3,595 of 6,742
The Elear is a bit heavy at 450g, but it's very well distributed. Very good fit, very plush headband and the softest pads I've felt. The wheight of the headphones+the massive stock cable may cause some fatigue on the neck though.
Jul 14, 2017 at 1:48 PM Post #3,596 of 6,742
Does anyone know of a retailer in Salt Lake City where I can demo an Elear?
Jul 14, 2017 at 2:50 PM Post #3,598 of 6,742
I bought one of these last week http://www.ebay.com/itm/Focal-Elear...Canare-Headphone-Cable-Balanced-/172727863595
The seller also customized the length for me, I wanted a 6ft length from the XLR to the splitter, for no additional charge.
Here's another cable for a similar price http://www.ebay.com/itm/New-Dyson-A...R-MPH1000-SPOCC-Headphone-Cable-/112415758019
More or less the same as the £15 cable I use with mine? The stock cable has been in the box ever since. A shame, really, as the quality of it is ace, just waaaaay too long (for me)!
what is the best reasonably priced replacement stock cable? this thing needs to go! Moon Audio's is ~$400USD or something...
Jul 14, 2017 at 3:37 PM Post #3,599 of 6,742
i got Lqi cables from ebay. ~$150 for silver-plated copper with balanced 4-pin XLR termination. i like it.
Jul 14, 2017 at 4:21 PM Post #3,600 of 6,742
The Elears are noticeably heavy, but the weight doesn't cause any discomfort for me. What does is that the ear cups are sprung which causes them to put pressure under my ears.
