SnapperMusicFan
Has anyone tried the Elear with a Feliks Elise or similar?
This is interesting... I have the Elears on my head now and I pushed the cups in with my hands (not to cover up the cup with my hand) and it is neat how it changes the sound... Not sure what to make of it though. Listening to Tool now and its fun to play with it ha.Well, after more than 120 hours with the headphones I would like to report that I am really pleased with them, notably for rock and metal. For classical and instrumental music I still prefer the HD800S.
I would like to add, though, that bending the headband (especially the metal parts that hold the cups) so that the drivers are closer to your ears, really improves the sound of Elears.
Just curious, how bad is the dip in the upper mids/lower treble on the Elear?
What about the clamping force and comfort? Does it increase too much?Well, after more than 120 hours with the headphones I would like to report that I am really pleased with them, notably for rock and metal. For classical and instrumental music I still prefer the HD800S.
Ordered the 1.4m, 3,5mm terminated Beyer T1 cable for my Elears. 99% of my listening is while I'm at my desk, which is literally <60cm away from the source, and although the stock cable makes a nice truly nice scarf it becomes a bit of a handful when there's 3 1/2 meters of slack to manage.
Has anyone found a decent case for these?
Yes, good question about what is a good case. Anyone?
Thank you brother.Yes, sir, the clipping noise is normal. It is a design choice to avoid distortion at high volumes. The Utopias also have the same safety mechanism, although at higher levels.
Monoprice 13"x12"x6" weatherproof case:
The bottom foam is a little thick, so they get squished a tiny bit when you secure the lid, but I don't believe they are being harmed in any way. Swapping out for pelican bottom foam, which is denser but thinner, would be ideal.
