- Dec 27, 2010
Waiting for my adaptors, so I can try these with my balanced HEK cables and my Liquid Carbon.
I'm no expert (couldn't MOD a paper bag), but my impression is that you can use a balanced cable with an adaptor ďso presumably you could change the termination), but you can't go the other way (single ended to balanced) that way.
The Utopia doesn't sound bad on the Mojo so maybe try it that one out for the Elear?
Is the mojo A big step up from the DFR? I was considering the mojo or maybe the Audeze Deckard or Marantz HD-DAC1.
Can anyone give me advice on which would be best?
Thanks
Are you saying that since the stock Elear cable is unbalanced (TRS connector), swapping the TRS connector with a 4-pin XLR is not possible?
How's the bass distortion problem going?
Also, does the upper mids/lower treble dip make female vocal terrible?
I planned to get an Elear for jpop(female vocal), rock but these two problems keep me from pulling the trigger.
Things that bother me about the Elear are comfort, recessed midrange and a strange "honky" quality at times in the midrange, especially on classical strings which I listen to a lot.
I listen to female vocal all the time and I would not describe my listening experience as terrible. Quite the opposite actually! I listen to Adele, Emile Sande, Birdy, Diana Krall, Norah Jones, Sia, Sarah McLachlan, Sara Bareilles, Kristina train, Kate Bush to name but a few and they all sound fantastic to me with my Elears
