Mmm....excellent review of the Utopia. Question: can you list the audio chain that you utilized to arrive at your conclusion? Tia.
Focal Elear and Utopia Review / Preview With Measurements - Head-Fi TV
- Thread starter jude
- Tags
- focal focal-elear focal-utopia
DKMTech
- Aug 15, 2016
Does anyone know when the Elear will be available?
On Focal's website, it says I can pre-order them.
I cannot find any places to actually buy them yet.
dpump
- Jun 23, 2001
for those looking to DIY or purchase aftermarket cables for Elear:
Assuming that Tyll's measurements are correct (NO REASON to doubt Tyll) :
this should fit comfortably into the socket http://www.viablue.de/com/phono_plugs_3_5_t6s_small.shtml
For a relatively cost effective and reliable ready made SHORTER cable OR a balanced one there are the beyerdynamic cables meant for the T1.2 and T5p2
http://europe.beyerdynamic.com/shop/audiophile-connection-cable-1-40-m.html
http://europe.beyerdynamic.com/shop/connection-cable-audiophile-3m-balanced.html
The connectors on the Elear that Tyll shows are mono connectors. The Neutrik Rean connectors Tyll recommends and the Via Blues recommended here are both stereo connectors. I also checked Norse Audio and he is selling the Eidolic connectors that are stereo. I assume you use the tip and sleeve connections and leave the ring unconnected? I know Neutrik Rean makes a mono plug also so why not use it instead of the stereo plug? The Reans are much less expensive than the Eidolic and Via Blue but the latter 2 are better quality and have larger rear cable openings.
I ask for no drinks
http://www.head-fi.org/t/817283/ic-focal-elear-shipping-and-paypal-fees-included-can-ship-immediately
I used these ones in my MHP1000 and now with the Elear. They work great.
http://www.ebay.com/itm/10-Pcs-Copper-Gold-Plated-1-8-3-5mm-Mono-Plug-Jack-Audio-Male-Plug-Soldering-/281825048985?hash=item419e14f999:g:U8UAAOSwo6lWGqrN
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
DKMTech
- Aug 15, 2016
Thank you Musicday!
I may have to buy you a few drinks anyway, even against your wishes.
Thank you Musicday!
No worries,glad i could help.
Let us know when you get them, and welcome to Headfi.
DKMTech
- Aug 15, 2016
Thank you for the warm welcome.
bidn
Hello,
I would like to buy the Utopia
but at this point my desktop gear probably does not match up the Utopia
(I have a Pioneer U-01 DAC and an iFi iCAN PRO amp).
I would like to know which desktop DAC and amp would match the Utopia.
Which ones would you recommend for the Utopia?
Would the Shiit Yggdrasil DAC or the Naim V1 be good enough?
I have negative prejudices re. Chord devices, not because of their apparent excellent SQ,
but because:
- I often try to listen (and also do things on my computer) with as little light as possible and the Chord lights seem quite disturbing and irritant to me
- their devices do not seem to be practical to stack with other devices
- they seem overpriced (I heard of people buying a Chord Hugo, and then adding the same additional capacitors and connectors as are found in the Hugo TT plus a bigger case, the add-ons costing a fraction of the price difference between the Hugo and the Hugo TT).
I also have a preference for smaller devices and for those who consume less energy,
but I realise the later may not fit with the requirements for the highest SQ.
Would my iFi ICan PRO be good enough as an amp for the Utopia?
I live in Europe, so certain equipements such as Cavalli which may not be marketed here are no solution for me,
however Schiit products are sold in Europe.
Thank you for your answers,
bidn
but because:
bidn
- Aug 2, 2014
Audio Chain:
Macbook Pro running Amarra for Tidal > Audioquest Jitterbug > Wireworld Starlight 7 USB 1.0M > Schiit Wyrd > Wireworld Starlight 7 USB 0.3M > Audio-GD DAC-19 > DanaCable Onyx RCA Interconnect 1.5M > Cavalli Liquid Crimson using 1975 "Holy Grail" 6N23P Reflektor tube w/ single wire getter post > Utopia Stock Cable > Utopia.
Power Chain:
Liquid Crimson: Wireworld Electra 7, DAC-19: DIY 7AWG Yarbo Flatwire w/ Oyaide 079 Series connectors, Power conditioner - PS Audio Duet, Power conditioner cable: Pangea AC-9 II.
- Aug 2, 2014
Hello,
(I have a Onkyo U-01 DAC and an iFi iCAN PRO amp).
but because:
- their devices do not seem to be practical to stapple with other devices
- they seem overpriced (I heard of people buying a Chord Hugo, and then adding the same additional condensators as are found in the Hugo TT plus a bigger case, the add-ons costing a fraction of the price difference between the Hugo and the Hugo TT).
bidn
IMHO, the iCan Pro is a sweet amp. I prefer it to any of the amps in the Schiit lineup, personally. I can't remember if they had it hooked up to the Resolution Cantata or the Mytek Brooklyn at RMAF last year (they both have a silver hammer-finished front... it's confusing!) but the PRO can scale really high with a good DAC.
grizzlybeast
My name is grizzlybeast and I'm an audioholic.
Hello,
but because:
bidn
+1
alsoSchiit Yggdrasil DAC is great.
FLTWS
Yes, it is !
Yes, it is !
+1
Yes, it is !
pkcpga
I'd go with a list of DACs before the schiit Yggdrasil, the chord Hugo is a great DAC and the naim DAC v1 is very good as well but definitely is not as transparent as chord DACs. You really should listen to the DACs before buying. I love my chord Dave and like my naim DAC v1 for its price point. Also if you have any DSD music the Yggdrasil does not play it.
bidn
Thank you so much,
Hansotek, grizzlybeast, FLTWS and pkcpga for your clear and to the point replies!
So I understand that my iFi iCAN PRO amp would be good enough for the Utopia,
and that I may only need to purchase the Schiit Yggdrasil.
I do believe the Dave has top sound but I am not ready to expend so much money
(and I don't like the lights its shows nor do I find its casing practical, although very beautiful).
The best cable I own for connecting an amp to a DAC is a Oehlbach XXL-2 8.5 mm Cool Silver,
would you also have an idea whether it would be good enough
for connecting the iFi iCAN PRO to the Yggdrasil,
and not creating a bottleneck between the two in view of the performance of the Utopia?
Total: 8 (members: 0, guests: 8)
