I ended up buying the ZMF crescent snap (without leather) along with their perforated suede pads.Has anyone tried the ZMF Crescent Snap with the Clears? I have the geekria headband but was hoping for a bit more padding.
The crescent snap fits fine, though was a little tighter than the knitted fabric geekria cover to get on. The headband is noticeably more comfy now, but if you're not having issues with comfort with the geekria cover already I don't know if I'd recommend it. Also note that due to its height, you need to add roughly 2-3 clicks to the headband adjustment, so if you're near the high end already it likely won't fit properly.
As for the pads, they're better than the dekoni ones imo. The sound difference from stock is pretty much indistinguishable to me (as also evidenced by the measurements zach took in his video), and I'm a fan of the extra space in the cups. The clamp is slightly higher, but it's not a deal breaker. Something else I didn't realize I'd appreciate also is the fact it has a thin fabric cover inside - for me the cups tend to accumulate a ton of dust and dead skin without this.
(the ridges in the fabric are actually molded into the foam, not slack in the material)
