After enjoying the HD660S for a while, with a journey that started in 2007 with the Audio Technica AD700 and going through many mid-range headphones, I am upgrading to my end-game
Focal Clear. It has shipped and I await its arrival.
I'll be connecting it directly to my PC soundcard (
I do plan to get a DAC/AMP somewhere down the line in the years ahead), which is a
Creative Sound Blaster Z, so for now it will run unbalanced. Since the headphone does not arrive with a 3m cable that ends in a 3.5mm plug, I will have to use an adapter.
I could just get a 1/4 to 3.5mm, but I would rather not risk a cable break at the back of the PC with a long extension towards the wall. So, I am thinking of getting this
4-Pin XLR to 3.5mm (
linked below),
just wanted to confirm if this will be fine to connect to the 3m XLR cable that comes with the Focal Clear?
https://www.amazon.com.au/gp/product/B0B465M3VH/
EDIT: Actually, found this that arrives within 2 days, instead of having to wait almost a month for the above to ship from the US.
https://www.amazon.com.au/dp/B0BL3XRDM9
I do worry about the quality of the latter though, so if it's recommended to order XLR to 3.5mm I linked first in terms of quality, as it uses a 22AWG copper cable, I will order it and then not worry about when it arrives.
