Hello everyone!
I’ve been thinking of making quite a big jump from mid-tier to hi-fi and the Focal Clear is at the top of my list. I love the design and look, it seems very comfortable and of course it’s amazing sound.
Would Focal Clear owners suggest it worth the jump from the HD6XX/Sundara tier? Has anyone compared it with other headphones at the same price point like the Hifiman Arya or ZMF offerings? The Clear appeals to me the most but unfortunately I don’t have any places near me where I can demo this stuff. My only concern atm is the cost of replacement pads. How often do they need to be replaced? I’m generally very good to my gear and my skin often stays clean and I take care of my hair.
Except of the ZMF I listened to all those headphones quite a lot before making my decision.
The Arya and Clears are a big step up from the HD660S and Sundara, at least with my source, the Chord Hugo 2.
Comparing the Arya and Clears:
In my area, the Arya is €1600, the Focal Clear are currently <€1000.
The Arya is a great headphone, very transparent, detailed, great soundstage, smooth, maybe a little aggressive in the treble and a little dark in the bass.
The biggest issue I had was that IMO they had a little different character in the different frequency areas, dark bass, smooth, transparent and great layering in the mids and a little sizzle in the treble.
The Clears have a tighter sound and soundstage, are very coherent from top to bottom, and I feel they are more versatile.
Detail and clarity is also very good, especially at lower volumes. Soundstage depth and layering is not as spacious though as the Arya.
Edit: one additional limitation is that they are limited in sub bass volume, so if you like to listen very loud with bass boost you will run into clipping.
Another aspect - the Clears are heavier and have more clampig force than the Arya, but I can wear the Clears for hours without discomfort.
One thing to keep in mind, the Arya is very power hungry, the Clear is easy to drive.
If you go for the Clears, I would recommend the PRO version as it comes with 2 pairs of pads, and the dark pad color makes them much less sensitive to dirt and grime. I also find the cable selection better than with the regular Clears.
I first bought the grey Clears and even after casual listening for a week or 10 days the pads started to show discoloration, so I returned them and got the Pro version. I really don't regret it, they look great and are much less sensitive to dirt. The extra set of pads is the icing on the cake.
