how much more bass amount would the clear have over the hd 800 s and would it have a bit less treble amount then the hd 800 s?
i ordered the hd 800 s as they seem to be what i want, but if for some reason i dont like them, the focal clear was my next option to try
i used to own the hd 6xx and i currently own the lcd2 classics and would like more treble then what they both have but not as much as the beyer dt 990 for example, and for bass i want more mid bass from then say in the flat presentation on the lcd2 classics for example, and the hd 800 s seems to fit all of that while being lighter in weight and having more comfort then my lcd2 classics which is also important
but like i said if the treble is too much still i might consider the focal clear, if its not though, and the bass is equal to the amount of the hd 6xx or more then it will be fine also
but i think i will be ok as lately the way i perceive sound has changed and i am now able to listen to my music at what most would consider normal listening levels as i used to listen at lower volumes as "normal listeing volumes" would give me anxiety as my doctors have said due to my autistm certain sounds are more or less likely to bother me, and the treble on the dt 990 is not painfull like it used to be for me and on some songs is even enjoyable, but for others like in some edm songs i listen to its still a bit too much, so i am hoping the hd 800 s will be everything i am looking for
