phthora
So my Clears arrived today. Initial impression (with maybe 20 minutes of play) is very positive. Take the below with a grain of salt given my limited time, but: The overall sound profile is much in line with the Focal sound. Very neutral with impressive clarity and resolution. Going from memory, similar clarity to the Stellia, not quite as forward in the mids, not as smoothed in the treble region, but similar levels of bass. The Clear soundstage also feels a little more spacious and, well, open.
Not as much slam as the Elear /Elex and no mid bass emphasis but deeper, cleaner and less intrusion into the mids. Detail and clarity are well ahead of the Elex / Elears. And there seems to be less of a hole in the lower treble region. Soundstage also feels more open here too.
Compared to my MrSpeakers AFC, the Clear sound is noticeably less colored. The AFCs are warmer but a little metallic when compared to the Clear. The Clear has a more realistic rendering of mids and lower treble, if a touch dry. The Clears slam a little harder and reach a little deeper but the difference isn’t huge. The MrSpeakers bass is a little cleaner, and faster and the overall sound is a little more romantic, but not as true to the recording. Both the Clear and MrSpeakers are very detailed and resolving. Soundstage of the Clear is better. The AFC is more comfortable, though neither headphone is uncomfortable. I suspect the Clears will get more comfortable over time as the pads soften and clamping force loosens up.
Well, your initial impressions match my 9 month impressions, so I'm not sure any salt is needed. You've listened to and described the sound very well, if you ask me. Nicely done.
As far the clamping is concerned, I haven't noticed mine lessening at all, but I have managed to wear them in such a way that particular problem was alleviated. I found them clamping quite a bit harder on the bottom of the cup than the top, but positioning the headband back farther on my head helped a lot.
