I’ve found the Herron 5 and a good R2R DAC provide plenty of warmth, while maintaining the clarity for which the headphone is known.
I have not heard of the Herron 5 but a good R2R DAC is the way to go.
I have let the Clear run in continuously for about 10 days and I can now safely say that i don't really have an issue with the top end anymore. Another thing...I found the clamping to be on the moderate to light side, so I gently flexed the headband for a slightly firmer grip, and this has smoothed things out as well sonically. The resolution of inner detail is quite something, and overall probably the best balance of any dynamic headphone that I have listened to.
Tristan a reviewer returned his Clear and raves about the Z1R. Tyrll a reviewer luvs Clears, not so with the Sony Z1R. . Clears do seem on the smaller size.Hey Beagle. I'm close to pulling the trigger on a purchase of the Clear, but I'm a bit concerned about the soundstage. I've read in a few different reviews that the soundstage is HD650 small. What say you?
My biggest reason for buying open headphones is for the wider, deeper soundstage and airy presentation. If the Clear isn't very close to TOTL in these areas, then maybe I shoud look at closed TOTL like the Eikon or Z1R instead. The Z1R intrigues me because of the wide soundstage in an isolating closed back design.
Ditto! Mine "might" be delivered tomorrow though.
Be aware that the Z1R has a very distinct sound signature. I would call it a niche headphone. It does some things like not other, bass quality and quantity, and for a closed HP, it does indeed have a relatively large soundstage. But the tonal balance is far from neutral. It's 'thick' sound is not for everyone and every genre. If you listen to a lot of EMD, and pop, it's great. Less so for jazz, acoustic and classical. IMO it sounds veiled with these genres.
Aeon Open vs Clear seems to be quite the question, doesn't it? Suppose Ether Flow shouldn't be discredited either but when it comes to flagship level performance at a somewhat reasonable buck, these two keep coming up recently.
I'm not really the right person to ask about soundstage because it is my view that the actual soundstage is in the recording and will be properly reproduced by two matching drivers. Moving the drivers away from the ear exaggerates this. But a lot of people claim that this is what gives headphones a unique "soundstage" that can only be appreciated (or not) by the particular individual listener.Hey Beagle. I'm close to pulling the trigger on a purchase of the Clear, but I'm a bit concerned about the soundstage. I've read in a few different reviews that the soundstage is HD650 small. What say you?
Which one would you say is more accurate (true to source)?I have both, enjoy both, the Clear is more dynamic, the Ether has a bit bigger headstage. I tend to reach for the Clear first, they get far more head time. With the Ether Flow being held for when I want a more relaxed presentation. You really can’t go wrong with either one.
