Paulo Abreu
Does anyone have a DAP recommendations for the Clear? I believe at least one person was using a Fiio X7 mark II with good results (of course, the amp selection makes a difference). I listen to my headphones in multiple areas of my home, so a DAP would be what I use 95% of the time with the Clear.
I'm currently using an LG V20 as a DAP with my Fidelio X2, but I'm planning on upgrading both and may start with the the DAP. I'm looking for an Android DAP that plays FLAC and DSD in their native form while also allowing for streaming. It sounds like the Clear may be a little bright, so I don't want to buy a DAP that adds any glare/brightness. If anyone has experience with a DAP that compliments the Clear, I would appreciate your thoughts. I'm currently leaning towards a DAP with interchangeable amps so I can switch amps if needed to alter the sound to my preference. I know the Clear are efficient, but there are reports of improvement with more powerful amps, so I don't want an under powered DAP.
I've spent some time listening to a few locally available headphones. Having heard the LCD-X and HD800S, I've learned that I want something in between the two and from the reviews I'm reading it sounds like the Clear would fit my preference. I found the LCD-X to be too warm/bassy and although I enjoyed the clarity and soundstage of the HD800S, I found them to be too thin sounding as a result of what I perceived to be a lack of bass (they were both connected to a McIntosh amp that was better than anything I plan to use). I would buy the Clear first, but I know that if I wait I can get it for hundreds less.
Any experience with how the Clear sounds on particular DAPs would be very helpful.
I have X7 ii and very pleased with the combo - AM5 has plenty of power and matches very well Clear, maintaining the detail and clarity of its signature. Before getting AM5 I've had AM1, AM2 and AM3 on X7 1st, AM3A and AM5 later on X7 ii, reading the feedback from FiiO forum I would expect AM5 to be "warm" and with a bit of rolled-off treble, it isn´t !! its a great AMP
