luklak
- Jun 5, 2008
Sorry, did not mean to scare you It was the first thing I noticed when I put them on, so if you did not notice it yet, yours are probably ok. Maybe each piece is different in this regard.I have not noticed any white noise or hiss with mine. I’m almost afraid to even listen for it now though, given others have that issue.
I don't know exactly how to describe it, it's like a distant waterfall or a sound from a sea shell. It's present in most of the ANC headphones, so I did not expect completely black background, but for me it was just surprisingly loud on Bathys (compared to others) and it really started to bother me. But maybe I'm just too sensitive to this. Also on Soft ANC mode I would expect this hiss to be reduced, since the ANC in that mode most is almost negligible. For example PX8 also have this slight hiss, but it's barely noticeable and does not bother me.
I guess the best solution would be to add the option to disable ANC completely (leave DSP on, just switch off ANC), but I'm not sure if this is possible just with some firmware update. I think Focal created Bathys to be used mainly as a portable headphone used in noisy environments, in that case ANC always on makes sense. For usage in relatively quiet environments passive closed headphones would be better - but for me using bluetooth headphones while working is a matter of convenience (no cables, no DAC/AMP needed, you can just walk away from desk with headphones on).
I'm still not sure if this is a deal breaker for me - I'd like to keep them, because for my ears the sound quality is the best of the bluetooth headphones I've tried (Sony XM3, Aonic 50, Momentum 4, PX8). PX8 have less hiss, better comfort and build quality, but the sound is just not enjoyable for me (I listen mostly to orchestral music, and I think PX8 is better suited for other types of music). I did not try ML 5909, but I've read that is has similar problems with this ANC white noise (also I'm not sure if ANC can be switched completely off).
