Vitaly2017
Do you know if you’re dropping by Toronto this weekend?
Have a 4.4 to 2.5 adapter ready
I am on my way to spruce pine Nc maybe on my way back, will see
@Rockwell75
Its also important to consider how strong is the sound... Its all great to have a lot of mw power output but if it has no guts and all it does is more volume but no depths then what is good of it to raise volume?
I am not saying m8 is thin or has poor sound.
It just has less guts power then 1z and sp2k this is where the ToTL daps draws the line and M8 dont touch it....
Sp2000 has same sound quality even when you raise the amp volume high, this is thanks to ak engeeniring the best audio path possible. Effectiveness and stability to the max.
By the way ak never gets hot why? Cause its super effectively optimized like 1z...
