Jan 29, 2017 at 11:07 PM Post #5,973 of 7,931
Question...One of my housings (ulf housing) isn't solid...The filter juts out a bit and even comes loose (have already lost one filter)...Anyone else also ever have this happen?
I have ULF filters pop out all the time.   Truth be told; the ULF filters are my least favorite part of the FLC8S experience.   They fall out; get lost, and with my replacement set ordered from LMUE one of the six arrived squashed and is unusable.
Jan 30, 2017 at 12:07 AM Post #5,974 of 7,931
Just curious, are you guys frequently or semi-regularly swapping filters or is the "gasket" just failing on it's own?
Jan 30, 2017 at 1:19 AM Post #5,975 of 7,931
Ouch. It must be terrifying to have one of the filters broken when they are delivered. Took me about 2 weeks for them to arrive. I'd be devastated if that were to happen to me. Does the ulf filter slowly crawl out or ?
Jan 30, 2017 at 1:41 AM Post #5,976 of 7,931
I've had one of the ULF gaskets move out of place and start to slip into the shell. I used a pair of tweezers to gently (emphasis on gently) pull it back out and reseat it. Everything's been fine since then. I've never had a gasket spontaneously pop out, and I've had FLC8S for quite some time.
Jan 30, 2017 at 10:54 AM Post #5,978 of 7,931
When my failed, I'm certain it was due to overuse. I was switching between red & gray daily. I don't see how the gasket could fail if you pick a ULF filter and stick with it. I know it's not as fun as constant adjustment, but it doesn't appear the ULF port is designed to take a lot of abuse.
Jan 30, 2017 at 12:46 PM Post #5,979 of 7,931
this is my situation...because it will jut out on an angle...then eventually pop out.
going to try this...thanks
Jan 30, 2017 at 2:30 PM Post #5,980 of 7,931
Noted. I guess I will just have to stick to gray/gray/gold and be happy!
Jan 30, 2017 at 7:45 PM Post #5,982 of 7,931
yes experiment, be open.
due to my losing one of the ULF filters has made me creative:
in one ear is red...in the other black.
i do remember jokerl saying that in  his op there is
not much of a difference....so i have a new hybrid ULF
Jan 30, 2017 at 10:57 PM Post #5,983 of 7,931
Ordered Saturday, off eBay, arrived in my mailbox in the KC area, TODAY! Crazy fast! All thanks due to a listen to nmatheis's pair. Thanks, man!
