Paulus XII
Formerly known as FW214b
What's the trick to easily detaching the cables? Slowly twisting and pulling as suggested by the manual don't seem to be doing much.
Push gently.
Wew, kinda scary then.
I recently eyeing on oyaide hpc ue but still not sure it will match or not with 8s.
I also saw comment says that silver upgrade cable has same lenght with original one which is little too short.
It's tf10 original connector. from a same supplier.
tf10 0.75mm can't fit mine so I have to resort to 0.74mm...
I tried with a variation of tf10 cables but it does not make the cut ):It must be a very, VERY rigid material if it's so precise as to not allow an extra 10 microns in there. Lol
all for the pursuit of better soundDat tolerance! :eek:
@Flcforrestwei
what are the manufacturing tolerances applied onto the socket? I have a feeling that they might be a hair too tight then.
What's the burn in time for the dynamic driver? The low end is currently not as significant as my IE80s. Also, does the original FLC8 cable really favor the low end and reduces brightness? I ordered them regardless because the stock cable does not like glasses and is microphonic.
Try using the red ULF filter. If that doesn't have enough bass for you, add the black LF filter. That should do the trick. After hundreds of hours I don't hear any change that could be attributed to physical burn in. IF there was any change it was so gradual that it's most likely brain burn in.
I really like the sound upgrade with my new FLC Silver Crystal cable, but it doesn't have the original FLC8 cable's feel, weight, tangle resistance.
I was already running the red and black, along with the blue nozzle. I'm no basshead but after using the IE80s for a year, it's quite apparent to me that the low end is definitely not as powerful comparatively. The comfort and fit however is superior and once the replacement cable arrives, will be even better.
