crazy eddie
- Dec 15, 2015
Ok guys I was scared at first , when I connected to my cowon plenue d, it sounded horrible and it felt like there was an imbalance, so burn baby burn I did, first I used my x5 1st generation with 12e, after two hours, it was a different iem, then jumped to the xduoox3 with fiio 17, and used house music with vocals, and a few track for bass made for car systems, now they improved on bass ,but it wasnt like better than my triplefi.10, because with my triplefi.10 I can eq everything, that's the beauty of that iem, now I was using, yellow,grey,grey, and its awesome, but I read jokers review and changed to red,grey, and dark grey,and 5 days later it's wow, I haven't given that much use sine my preference for now is my xba a3 with x5 and 17 or 12e,so I used the 12e with some harder music and wow, it has opened up, now I tried the cowon plenue d again, and in no way should this little thing have bass like this, the trick of amps is to get more of details and bass without having to top out or go to the point of any distortion. A lot of people don't know that the 846 has an internal amplifier, which give it an advantage, but any amp will do the same provide you have good reason order music , even mp3 in the best quality sounds awesome, now there is another secret but it's not a must, called either mojo,cayin c5, ifi dsd dac,amp,but the best of all penmy for penny is,the cayin, because it has the 3d effect of the ifi, and it extra power is needed you can stack two, they have one with a dac and the other without, so two will push anything, and ceaper, and open box and used ,are usually good,well of course you gonna check out the seller
