dj nellie
- Oct 9, 2009
Yeah, your post motivated me to finally hook up my Solo to my Lavry DA10. I'm playing a 24/96 file in FLAC Player (Verizon iPhone 4) and my Lavry is showing 48khz as the sampling rate. Kind of disappointing, although I'm not sure what to make of it. My Lavry shows the correct sampling rate when I use my M2Tech hiFace as a transport from my computer.
Seems like FLAC Player is not actually capturing the hi-res info?
So I finally got a DAC that displays the signal resolution that is being fed to it from my CLAS and it is reporting that all my 88, 96, 176, and 192 kHz files are being down-converted to 48 kHz - has anyone else conducted the same test on your equipment? The file size loaded on my iPhone is the same as it should be, so I don't think anything is happening in the file transfer process...
Dan, can you please comment? Is Flac player or Apple iOS the guilty culprit? Have you already tested this and the fault is on my end? And if it is Flac player, any chance to get this fixed?
