Zoide
- May 2, 2004
Does anyone know why musicaacoustics got banned? Also, if you try to go to gd-audiobase it says the account has been suspended :blink:
Click your link. Then read the fine print below the nickname.
I know how to click on links, but thanks for your great contribution.
It says "now known as DmitriTrush". I'm guessing that's the owner's name, but I still don't know what's going on.
Does anyone know if any of the Comply tips or the Shure olive foams fit the mrkii? I've discovered I have different sized ear canals and i can't get a good seal on my right ear. Driving me mad!
Hi.
I have the Fischer DBA-02 MKI,and I ask if I can use these olive foams.In case I can,is there only one size,or different,and where can I buy them?
Thank you in advance.
How can I check what size have I to buy,because I see that there are three kind of foam sizes S,M and L.
Obviously, it is much too early for a review. I've had these things in my ears long enough to give me earache if these were the CK10. Thankfully, there is no metal plate anywhere that sticks out. These are VERY comfortable in the ear, very small, and very light. Overall, a bit lighter than the CK10, a bit thicker at the housing, but a smaller footprint in the ear.
As you know, I've not used the MKI before, so I'm not used to Fischer. In fact, before I got these from Musica Acoustics (thank you Dimitri!) today, I'd never used a Fischer product before.
Sound bites:
Very smooth, powerful if slightly understated bass. Understated as in detailed and powerful, but gives air to the mids equally. Very very lovely sound. I'd think that people who have the SM3 but want something brighter might like these though they are not as warm as the SM3.
For classical: Mozart Symphony No. 18 in F
Great reach up top, but not abrasive. Good space and powerful, moving mid section. Bass comes in enough to bump in the bottom, but gives support to mids. Violins are beautiful. Here, the MKII bests the CK10 for sure. Where the CK10 borders on shrill, the MKII rifles in speedily, but without attendant screeching. I find this a more comfortable (long listening) earphone for classical (so far) than the ER4S or the CK10.
DBA-02 MKII: Grade: A
CK10: B+
For electronic: Frank Molder Firefly
Overall impression is competent, at times genius. Genius is the very smooth, extended highs that melt into their surroundings. Better presentation than CK10. Bass is adequate, even oomphy at times, but again, the melting of mids and bass smoothly is the kicker. Many spacey sounds wrap around the head perfectly in wide arcs. Very trippy for IDM and slower electronic music. A thicker mid-oriented bass (like that found in the ACS T1) would be killer. As it is, I find these very good, but not excellent for all types of Electronic.
DBA-02 MKII: Grade: B+
CK10: Grade A
What's to love:
Cable: build quality is very good, very strong. I won't be swinging from trees off these, but I swear a small person could without falling.
Comfort: very very good both up over the ear, and down, like an earbud.
Accessories: there are millions of ear pieces there! I'm floored. And the case is very very nice.
Sound: in a word, perfect. As everyone knows, the CK10 has been my benchmark since 2008. For build quality, it still is. The DBA-02 MKII, however, is a smoother, slightly deeper, slightly less fatiguing sound than the CK10. These will grow on me, I'm sure. But, it doesn't need to. I'm sold. I have no idea if these sound the same as the DBA-02 MKI or not, but I don't care. These are lovely. I'll put them in my list of top three for sound preference.
What's cause for pause:
Cable: flat cable is microphonic and moves around A LOT. I will need to find a cinch as I don't like the included ear guards. Cables should be round.
Plug: I wish it were L-shaped. It isn't, but it is well stress-relieved, and is very supple. Same with the earphone side stress relief. It could be better, but it isn't bad.
Considering that overall, earphone build quality seems to be going down among all manufacturers for the same prices, I think the DBA-02 MKII is very nice. I can't wait to spend a few more hours before bed with these. Speaking of which, there is NO way, considering the angle at which they enter the ear, you can sleep with them on your side.
Lotsa' love here.
