I received the uDAC-2 and plugged it into one of my laptop's USB port.
With Direct Sound, setting it at 96/24 (within the Playback Device panel), playing a 44/16 file in Foobar, I experience a slight drop out every minute or so, at 96/24 (with a 96/24 file) it becomes one drop out every 10 seconds.
With WASAPI, setting it at corresponding sample rate/bit depth within the Playback Device panel, no matter what file I play in in foobar.
Any idea what I may be doing wrong? or if the device is at fault?
EDIT: Those problems do not happen systematically, a restart managed to solve them and another restart made them reappear.
There's a huge hannel imbalance (at least +10 dB on the left listening through MDR Z1000, 108 dB/mW, 24 ohms) before 9 o'clock, the only way to solve the problem is to decrease the volume in Foobar/Windows and turn the potentiometer further.
EDIT2: it still seems that the left channel is somewhat louder even at higher volumes.
EDIT3: With measures this times, right at the start, very little channel imbalance, there's a point around 8h1/2 where the channel imbalance reaches -8.5 dB on the right, and the channel imbalance decreases regularly as I turn up the volume to end up at -0.3-0.4 dB on the right channel. As I continue turning the potentiometer, there's a point just before 3 o'clock where the imabalance disappear rapidly and both channel are matched at .1 dB.
Note that this may be limited to my uDac, don't take it as a general statement.
EDIT5: I reported the channel imbalance issue at low volumes to Nuforce and they are sending another unit back. I will have to pay myself to send the original unit back to them, bummer.
EDIT4: RMAA here: http://www.head-fi.org/forum/thread/536324/nuforce-udac-2-rmaa-measurements
