FIRST IMPRESSIONS: NEW Nuforce uDAC-2 with 24/96 - USB DAC AMP with line out and S/PDIF out
Nov 20, 2010 at 9:01 PM Post #511 of 877
At first, I would like to salute the whole group of users here as I am new one. :-)
I have one question regarding difference between uDAC and uDAC2. I had the first generation of uDAC and I bought uDAC2 before a week, I noticed uDAC2 is warmer when it is working than uDAC. It is not something drastic but it is noticable. Do you have the same experiance and is this normal thing for uDAC2?
Headphones used : Grado SR125i and AKG K312P.
Vedran
That's normal — I guess it's partly due to the higher processing load to decode the 24/96 signal ... (just a wild assumption) — Don't worry about it ...
Nov 24, 2010 at 8:55 PM Post #512 of 877
Count me in on the u-Dac2. First headphone amp/source for my E500/TF10/Turbines/D2000.
Should be fun. Shipment to arrive Friday or maybe Monday..
Nov 24, 2010 at 9:43 PM Post #513 of 877
Yes just ordered mine as well, should be getting here on Friday, I'm very excited!!
Nov 27, 2010 at 1:46 PM Post #515 of 877
Ah I'm jealous, I kind of forgot about thanksgiving... therefore instead of getting the uDAC2 on Friday, I'll be getting it next wednesday!
Nov 30, 2010 at 8:28 PM Post #516 of 877
Hi,
Can you confirm that the uDAC-2 work fine in 24/96 with a MAC. For that we have to go to the audio midi setup and select the USB output and put it in 24bits and 96khz then open Itunes and play HD track without any conversion in 24/96. That's my understanding of the best way to play HD track. I read somewhere that we can't select 24/96 in the audio midi setup.
steve33
Dec 1, 2010 at 2:00 AM Post #517 of 877
Hi,
steve33
It works on a Mac computer, and you have the right proceedure.
Dec 1, 2010 at 4:28 PM Post #518 of 877
Just received mine yesterday. Got some time to listen to it through TF10. Seems to make things sound more distance. Need more time to listen to the difference there. My D2000s sound incredible with it though. Nice to finally have an amp for the Denons. Have yet to try them with the Shure SE530s. I hope they improve the sound of the Shures. Those were already my favourite IEMs for 4-5 years now (not that I have tried every other IEM though).
Dec 1, 2010 at 7:55 PM Post #519 of 877
Is anyone using the uDAC-2 with Sennheiser IE8s?  Any thoughts on synergy?
Dec 4, 2010 at 2:24 AM Post #520 of 877
I wish I knew, but I got rid of my IE8 a year ago, so I could afford to replace the Westone 3 that I lost.
Dec 4, 2010 at 2:45 PM Post #521 of 877
Hi,
steve33
I'm using a Mac and can confirm this as well.  I suggest installing Rogue Amoeba's SoundSource to make all your output tweaking much simpler and easier: http://www.rogueamoeba.com/freebies/
Dec 7, 2010 at 1:04 PM Post #524 of 877
So, I'm about to jump into the next level of audio with a DAC. At the moment I'm running an iMac -> Swan D1080MkII08 and i'm probably going to be adding some Sennheiser HD595 headphones to the mix.
So my question is, with most of my audio being V0 or 320kbps, is this going to be plug & play for me? Will I benefit setting up 24/96 if I have no plans for audio of that quality at the moment. Or should I just leave it at default settings? And is the uDAC-2 a good mix with my current setup if my budget is $130ish?
Thanks in advanced!
Dec 9, 2010 at 1:56 AM Post #525 of 877
Thanks in advanced!
It should be plug and play for you, and it still sounds good with 256-320Kbps compressed music.  I use mine to control my Audioengine A2 speakers, or listen to my custom IEM on my Macbook.  Only half my music is lossless, and only a small portion of that is 24/96 music.
As for 24/96, there is no reason to set it for higher with 16/44 music, except that with the iMac set to use it in 24/96 mode I think that you have an extra 8 bits for using software volume control if you choose to.
