What cable is that? How does it compare to the original Xe6's?"Easy" as Thursday FIRie Bunnie morning
Thanks.
Thanks.
I believe that cable is Eletech’s Ode to Laura cable which is a high purity copper only cable.
Thanks.
Ja, it's Eletech's Ode to Laura, a 22AWG, 4 wire, 9 core litz, triple OCC copper blend.
TBH I didn't listen to the stock Xe6 cable for more than 30min. First impression of stock was "eh" until I got used to Xe6's full bodied sound and bass. Not as detailed as I'd prefer but overall excellent OEM cable if you're not cable rolling. I swapped it out for Eletech's Aeneid 24AWG GPS which thins a bit of Xe6's fully body/thickness and adds clarity, opens up the soundstage, crisper treble and sparkle, more energetic.
Initial impression with Xe6 (silver ATOM) + OTL + Cayin N8ii P+ tube AB are mids a bit more forward and detailed, more air in mid snd upper treble, better layer and imaging while improving Xe6 low end with tighter bass – W sound signature.
do you have any recommendation for a cable at the Xinhs store up to 40$ or at least less heavy ?
As you can see from the above posts, people upgrade their XE6 and KR5 with $2k+ cables. Why would you want to downgrade pure copper stock cable with a budget aliexpress sub $40 cable?do you have any recommendation for a cable at the Xinhs store up to 40$ or at least less heavy ?
I just need a good backup cable but can't spend this amount on a cable...As you can see from the above posts, people upgrade their XE6 and KR5 with $2k+ cables. Why would you want to downgrade pure copper stock cable with a budget aliexpress sub $40 cable?
Why you are planning to replace FIR's $400+ stock cable with $40 AliExpress one?do you have any recommendation for a cable at the Xinhs store up to 40$ or at least less heavy ?
Just go with any $20 TRN 16 wire or simillar cables, they are good with i.e. KZ IEMs but they will rather "blanket" the sound of more expensive IEMs.I just need a good backup cable but can't spend this amount on a cable...
But the aesthetics of the Aeneid vis-a-vis Xe6 though is dope!
