Marvellous_DAP
- May 11, 2017
We have different sound preference. Had the Mojo for a while and didn't find it that good that you described. Sound is fine but the slight improvement or sound quality change due to preference over my iPhone without it does not justify having a interconnect cable and extra bulk.
Don't think the mojo has better details or clarity as well. I won't choose a Mojo over X5iii or X7II if sound quality is overall factor, as it is not better to my ears. It is just improving my iPhone in terms of enabling to play higher resolution files and better driving power. UI interface of iPhone with the Mojo to help with high resolution files are great combination with sacrifices of mobility and extra connection and interconnect, as compared to older DAP in the past. It is a different world now with all the new DAP with much better quality and sound improvements and much improved details.
Again, this is individual sound preference and my own experience and sound preference, Mojo does improve on iPhone SQ overall but not exactly better than the current top DAP, and there are many players with better sound quality than Mojo to my ears, not just X7II.
These are just my initial impressions. I'm not sure the X7 MKII should be compared to the Mojo or iDSD BL because to me they are in different categories. The Mojo and the Micro iDSD BL are dedicated amps/DACs. They both have more driving power and are two of the most well regarded portable amps/dacs you can buy at the moment for under $1000. The Mojo and the iDSD BL can drive full size headphones and IEM's with authority and sound good doing it. I'm not sure the X7 MKII can drive full sized headphones like the other two can nor do I think that this was FiiO's design intent with the X7 MKII. The AM3A does have more power output in balanced mode and the AM5 has even more power yet. But neither of those modules can match the output power of the Mojo or iDSD BL.
Comparing them, the Mojo and the iDSD extract more detail and nuances from the music than X7 MKII. But they are designed to be feed by a source while the X7 MKII is the the source in this case and is meant to be an all in one. The Mojo is a detail and clarity monster with very, very good bass. Music comes to life when I plug in the B&W P9's into the Mojo. It's really an incredible sounding pairing. The iDSD BL is not as detailed as the Mojo but it does a better job with a wider variety of music as I find it to be more forgiving with bad recordings. When using the XBass+ and 3D+ on the iDSD BL you can add bass, soundstage and depth to just about any headphone. It pairs well with all of my headphones and has more features than the Mojo and these features are not gimmicks. They really work and work very well. It even has iFi's well regarded IEM match processing built into it.
The X7 MKII for what it's designed to be is very good musically right out the box and this is a very good sign. I'm enjoying it very much with my SE846's the most. I haven't played with the EQ or Viper effects yet because the SE846's sound so good without using them. I'm sure I could enhance the sound and extract more detail from the music by using them. I could probably even get close to the Mojo or iDSD BL level of musical enjoyment if I tinkered around with these settings enough. But even with these adjustments I'm just not sure if the X7 MKII could best the Mojo or iDSD BL in power output, bass and treble refinement. They are just built for that while the X7 is designed to be so much more. In that regard, I think FiiO has winner on their hands. The FiiO is warm sounding, which should make it play well with just about any recording, it's musically engaging, it's feature rich, has interchangeable amp modules, it's very well built and feels good in your hands. I only expect it to get better the more I listen to it. It's well worth the purchase in my opinion.
