FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
- Thread starter superuser1
- Tags
- fiio fiio x7 mark ii
QuadraKev
- Apr 15, 2017
Went and signed up for Tidal Hi-Fi. I'll listen to some albums fully on 2.4 GHz and 5.0 GHz bands and see how it goes.
Jim Bobber
- Oct 24, 2016
Anyone here able to try the x7 iii with either oppo pm-3's or onemore quad drivers?
Paulo Abreu
Isn't it the same wheel as it was on X5-3? Should have the same play... #3 has some play as well, but it is much better this way, after using it for a long while, I got used to that!
Thanks for input George! Volume wheel seems to be fine, I was just curious to know. Btw, only took a couple of hours listening, not in the best conditions because of a headache but sounds great, considering your taste (AFAIK), you will like it
Regards
QuadraKev
- Apr 15, 2017
Mine has some too. It's a bit weird, but I don't think I mind all too much.
https://gfycat.com/gifs/detail/deliciousgoodguillemot
QuadraKev
- Apr 15, 2017
Hmm.. it seems like the Micro USB cable has some difficulty connecting with the silicone case on. The amount of space between the housing of the connector and the X7 MKII is a good bit thinner than the case.
Dobrescu George
Reviewer: AudiophileHeaven
I think that it is a tiny bit much, but still ok
I like the SE846's with the X7 MKII a lot. It drives them rather easily out of the SE connection. Bass is taunt and controlled, the mids don't seem over done and even the highs have some presence. If I were going to use the IE 800's everyday I would probably switch to the AM5 amp module, which I bought as well, for a little more power. The IE 800's seem to need it to sound their best. The IE 800's sounds good but my preference at the moment is the SE846 to use with the X7 MKII. They gave me that wow moment when I plugged them in.How does the SE846 sound with the X7ii? I've used them with the Questyle QP1R, so no meaningful comparison can be gleaned from that. I also used the IE800 on the Questyle, but couldn't get a good fit with the tips that can with it and for some reason, Sennheiser decided to use non-standard fittings for the tips.
Tidal HiFi is what I'm using and I'm enjoying the sound over WiFi. No dropouts, skips or anything just great sound. For my first DAP the X7 MKII is awesome.Went and signed up for Tidal Hi-Fi. I'll listen to some albums fully on 2.4 GHz and 5.0 GHz bands and see how it goes.
I am about to buy the x7II but just would like to be sure it will be better than the x5III with CA-vega only with SE output. Do you feel the difference at the first sight?
Thanks for the answer. I'm pretty sure I'll go for the SE846. What filters are you using?
I'm using the slow roll off linear phase filter with no EQ adjustmentsThanks for the answer. I'm pretty sure I'll go for the SE846. What filters are you using?
Sorry, I mean on the Shure's.
JaviAl
Can you try it and test in Balanced Mode?I can't hear any hiss to be honest. The AM3A drives them with authority in SE mode too. Maybe this is one of the upgrades to AM3A module. Like what Oppo did to the HA-2SE when they made it quieter.
brokengundam
Anyone else having issues with the player crashing when accessing/browsing a 256GB card in the fiio app?
