LamerDeluxe (tm)
When you push the screen with your finger do you see any ripple effect ?
No, I see no effect. Could this be part of the touch sensor?
Gapless on DSD was supported in ALL previous firmware versions until 1.0.6. The engineer has no idea of his own product he is working on. With such well-prepared engineers, the deplorable quality of Fiio's firmware and software (like FiiO Music) is to be expected.Dear friend,
We have confirmed with the engineer that the gapless on DSD function was not supported in previous firmware version.
The engineer will try to assess the feasibility of adding this support in later firmware update.
Best regards
No ripple effect also on mine
Even if you press harder you dont see any ripples or ghost effect at the edges of the screen? It is more obvious at grey background..
When i say ripples this is what i mean...the moving liquid of the screen. In my screen without any hard push the liquid easily seems to move, and i think that if i push a little harder that i will destroy the screen.I tried to push a little harder, but no. No ripples. Anyway since is lcd, where you push you see the liquid moving
Strange, because i tested with my Amiron Home which also 250Ohm on AM3A and it can driven them easilyI own X7mark2 with the AM3A i´ve test a DT880 Pro 250ohm which was sounds little bit "poor" i want to buy a DT1770. Is the "AM5" or the "AM3B" the better one for me?
PS: i known the DT880 and the DT1770 pro are different headphones... closed and open...
Dear friend,I am looking for the AM3E module.
Can we buy it separetely ? Or only with the Q5S ?
thanks !!!Dear friend,
The AM3E is not available currently. And yes, you could buy it separately.
Best regards
