FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
331 332 333 334 335 336 337 338 339 340
342 343 344 345 346 347 348 349 350 351
  1. FiiO
    Dear friend,
    You have sent the X7MKII back to us in China for check? You may try to burn the firmware for the X7MKII to see if it helps: http://fiio.me/forum.php?mod=viewthread&tid=41890&extra=
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  2. gazzington
    Thanks for replying. A lot of these audio companies don't try. You seem like when the good ones
    Peter Hyatt likes this.
  3. FiiO
    Dear friend,
    Actually we didn't do much in the sound quality in different firmware update. :sweat:
    We will try to add a +/12dB dynamic EQ in our FiiO Music on X7MKII in later update.
    Best regards
  4. lantian
    Fiio wont even agreed with us that anything has been changed or is different. I had a talk with their engineers a while back and they where certain that nothing about it's sound has been changed even though I hear differently. As far as Fiio is concerned it sounds just as great as once we bought them, so fixing it back to how it was is a defined no.
  5. bootster
    I had been told that the new firmware 1.06 had come out while my unit had been in FIIO's hands, and that you put the 1.06 on the device. The device states that 1.06 is the one on the device now. I tried without success to use this tool to flash the 1.07 that was going around these forums without success. I tried multiple times.
  6. lantian
    Strange the flash tool should always work, it even worked after the beta version completely messed everything up, beyond recovery. Try it with firmware 1.0.0 first and then try the 1.0.7 japan version
  7. Andrey2019
    Hi all.
    Things are definitely changed in 1.0.6 compared to 1.0.4. I do not say that sound is bad - I'm saying that it is brighter. And brighter sound is totally not in my taste...
    But as I said before - I perfectly reverted to 1.0.4 and now it sounds the way I like it.
  8. lantian
    Agreed, saying it sounds worse is a overstatement, it just sounds different. And totally not to my taste. I really hope the new firmware has the sound back to normal. The beta was pretty awesome for 4 days and then it totally died on me, I didn't like the sound of it though, but ui was amazing and most issues seemed fixed, well until it died.
  9. Andrey2019
    It is great that development is going forward!
    Maybe some time later in a custom modification signature will be fixed and we could use it. (something like this but for newer firmware: http://www.fidelizer-audio.com/fiio...6-released-with-bright-sound-signature-fixed/)
    Or maybe @FiiO could provide to us some other workaround to make sound similar to 1.0.4 - (like some specific settings in EQ or download and apply some specific patch from Fiio)...
  10. lantian
    I didn't like what fidelizer did to the sound and how it achieves what it claims to do. You can try Chinese version of 1.0.6. it also sounds different.
  11. Andrey2019
    I have not tried Chinese version (and do not want to do it). But if sound signature depends on language/country - then it is definitely a bug that should be fixed...
  12. PaxVobris
    Dobrescu George likes this.
  13. snip3r77
    We just hope that the new FW will arrive before Christmas
  14. Dobrescu George
    Xelento makes an awesome pairing with X7mkii, I also like this one! :)
    PaxVobris likes this.
  15. PaxVobris
    I have two days of Xelento. Sounds great with X7ii. I am busy rediscovering my jazz albums :))
