I have managed to have a few hours of critical listening now (on low gain), and I must say that the X7ii is a big step up in sound quality over my Cowon J3. I don't even feel that I need to mess with the equaliser either! Now I just need to choose some balanced cales for my SE535 but i'm impressed already.High gain mode is for high impedence (i.e. usually full-size) headphones.
Always go with the lowest gain option that works for your IEMs. Higher gain introduces more background hiss.
FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
- Thread starter superuser1
- Tags
- fiio fiio x7 mark ii
dbaker1981
- Apr 26, 2016
Does this have usb digital out?
- Jan 30, 2011
Yes - but FiiO doesn't guarantee it will work with any particular sources. It does work with the FiiO Q1ii and also the Q5. It wouldn't work with my IMS HVA or the FiiO E17K. So a bit hit or miss - which is probably why FiO doesn't advertise it as a feature.
dbaker1981
- Apr 26, 2016
Well I can say it doesn’t work with the ifi nano dsd black label. Do that means of the 5 daps I have none of them work correctly with it. I either get pops or just doesn’t work. Oh well guess I’m send that back.
haoyuan
Try the app Hiby Music in the fiio store.Well I can say it doesn’t work with the ifi nano dsd black label. Do that means of the 5 daps I have none of them work correctly with it. I either get pops or just doesn’t work. Oh well guess I’m send that back.
- Jan 30, 2011
So use coax instead of USB?
dbaker1981
- Apr 26, 2016
Fred-svv
- Jan 28, 2016
Someone tested the X7II Fidelizer Purist 1.0.5 rom? Any improvements?
Link to download: http://www.mediafire.com/file/wdtwtp3fv4hv1ou/X7ii-1.0.5-WindowsX-Purist.zip
mrmoto050
Ibasso DX200 already has released a 4.4 plug AMP4.Shouldn't it be both? (e.g. MUC-M12SB1 and also there are bundled headphones with 4.4 cables)
Really no large domestic manufacturers in China are utilizing 4.4 plugs, so Fiio is very wise to do it before other players catches on. In March, Fiio will release 4.4 balanced upgrade cables for their own IEMs as well.
Going on a tangent, I can speak from first hand experience that Sony players are extremely popular in China and upgrade cable market / philosophy is much more widely accepted. For example, I have gotten yelled at here on Head-Fi when I posted about upgrade cables because they think it's all BS, whereas in China I would get a lot of replies for discussions regarding the different cables and sounds. Because of the wide acceptance, there are many DIY cable makers on Taobao that will custom make 4.4 cables for a fraction of the price versus the US (where I am now), so there are lots of cables with 4.4 plugs out there floating around.
Iluin
- Jul 23, 2014
Hello everyone,
Did anybody tried to root their X7ii?
Also did anybody managed to download Tidal's offline content to an SD card instead of the internal storage?
Thank you and have a great day!
Oldnslo
- Jan 3, 2014
I've had the X7mk2 for a couple of weeks now. I use it mostly as a usb source for my car (the new high-zoot sony GS9).
I have a couple of issues:
1) the unit takes forever to turn on. My old X5? click and it's on. This? wait... and wait... and then welcome screen... and then fiio screen... and then start up fiio music.
2) there's no "click" or other indication for the user to know if the on button has been properly depressed long enough for the damn thing to start the "turn on" process. Nothing more fun than pressing a button for it to do not so much!
these are my Large Issues.
3) there's a whole lot of treble. I just now located the viper eq, so maybe that will fix it. i don't know.
I've got a Large Collection of wav files. And the music sounds heavenly both with IEMs and in the car. But, that start up process is maddening! Is there a firmware update for that?
gianfri
- Jan 14, 2009
I have over 100 GB of Tidal music on the SD. No problem.Hello everyone,
13-7
- May 19, 2015
Hello everyone,
I did. It is really simple when using Kingroot, but it comes with some bloatware, so I replaced it with SuperSU using Super-Sume-Pro. You probably can do this for free via Mobile Terminal, but I already owned the app and couldn't be bothered finding workarounds to circumvent Kingroot's annoying self-protection mechanism.
Not too many benefits atm, though.
Iluin
- Jul 23, 2014
Thank you for your answer.I have over 100 GB of Tidal music on the SD. No problem.
Can you tell me what is the brand of your SD card? Also did you have to do anything extra so that tidal recognises the SD card? Thank you again!
Iluin
- Jul 23, 2014
Thank you!I did. It is really simple when using Kingroot, but it comes with some bloatware, so I replaced it with SuperSU using Super-Sume-Pro. You probably can do this for free via Mobile Terminal, but I already owned the app and couldn't be bothered finding workarounds to circumvent Kingroot's annoying self-protection mechanism.
Total: 7 (members: 0, guests: 7)
