FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Dec 7, 2017 at 11:34 AM Post #3,213 of 6,207
Oppo PM3 sounds great with X7MkII, both with balanced or stock cable.
i got audeze sine instead of PM3 after a lot of review and I am glad i did that... sine with lighnint cable uses its own dac/amp with dsp and sound is just amazing...its fit is just tight which prevents me to use it for long
so i go back to hd 599 for that open sound with x7ii
Dec 7, 2017 at 2:23 PM Post #3,216 of 6,207
They are testing it before release. It won’t be far away now.
Dec 7, 2017 at 3:34 PM Post #3,217 of 6,207
I am not sure but i have used this to connect my android phones with usb c to the fiio E17k and they work flawlessly every time. Im not sure if this would support otg per se.
Like all of this OTG cables, the USB-C is the the host, the Android Device. For FiiO X7 MK II, needs a cable that the host be the micro-USB, the side and the connection of the FiiO X7.
Dec 7, 2017 at 4:44 PM Post #3,219 of 6,207
Frustratingly despite having signed up to beta test for them (especially regarding the SD2 problem) I haven't heard anything yet. Have you had the opportunity to test the new firmware?
Dec 7, 2017 at 5:03 PM Post #3,220 of 6,207
Device beta versions are not Google Canary or Windows beta, those can be really unstable, and unless you're ready to be a beta tester, it is best to not to it.
Dec 7, 2017 at 5:11 PM Post #3,221 of 6,207
Got mine today, sounds good. Any burn in period ? and changes ?
Dec 7, 2017 at 5:26 PM Post #3,223 of 6,207
Testing it currently - will be replying to Shadow later tonight.
Dec 7, 2017 at 6:15 PM Post #3,224 of 6,207
I run beta everything (I am a software dev by profession so it is par for the course)!
How are you finding it? Did they take a stab at the SD2 issue?
Dec 7, 2017 at 10:02 PM Post #3,225 of 6,207
Quite stable. They didn't specifically call out any improvements in dual card use - more with a couple of new features in "now playing" (which many will like), some Bluetooth tweaks and other features.
