Indeed, but some of them, like PowerAmp for instance, resample to a single frequency, instead of playing at the recorded frequency and don't support all the frequencies the DAC is capable of.
I consider DX200 with my firmware modification (actually, with some Android parts rewritten from the ground, and new software added) my end game DAP! DX200 is just unique on the market by its feature set. Do you take my point?
So yeah, I bought this over the AK70 MKII. I know it's a bit dopey to be too enthused five minutes after trying the player for all of twenty minutes but it's honestly night and day from the X5-III from my perspective on first listen. Quick question, is there a breakdown of how one should approach the low pass filter options? In layman's terms, what are the properties of each?
Hah, very helpful thank you, but it's super fun having lots of options all with advantages and having to select the advantage you want the most. I'd guess these are pretty subtle differences, but I like the sound of the minimum phase slow roll-off filter to go with the Z1R with its already pretty stellar bass. (by the way, a headphone I feel deserves better credit than its detractors bash it with with each day I own em)
just got my X7ii...great DAP and UI is not that bad as everyone is saying ... its fine for a DAP no lag etc
I just noticed that my sennheiser hd 599 with 50 ohm had to be on vol above 80 to really get most out of it even on high gain....I wonder if higher ohm headphones like HD 660s will play good on the am3a amp ?
and which filter you guys suggest for headphones like hd 599 ?
This is subject to debate at the moment. According to FiiO 3rd-party apps can circumvent Android's SRC and make use of the X7MkII's full potential, but it looks like this needs some tweaking on the developers' side.
Neutron works fine, though, as far as I can tell, the only exception being "native" DSD support.
Take note that the Samsung T5 side is USB-C (not micro-USB). I'm searching about six month for a short OTG cable micro-USB to USB-C (that the micro-USB side is the host) but at today that cable not exist.
That cable not run for this case because in that cable the host is the USB-C (to connect to the AK SP100) and the micro-USB is to the AK CD-Ripper (that is not the host). I own a similar cable and not run. Needs a cable micro-USB to USB-C that the host be the micro-USB not the USB-C. And today, that cable not exist.
I see. Seems like you know a lot about USB. I now understand that SP1000 becomes the host and uses the CD-Ripper as a slave (or USB peripheral device).
I have one question here. Usually the host supplies the power. But in this CD-Ripper setup, CD-Ripper supplies the power to SP1000 (charging). So the power direction is independent of this host-slave relationship?
