Hi,
What operation would get this? Thanks in advanced!
Best regards
Hi,
its all OTA apparentlyNew firmware for X7 ii ? link?
This is not photoshop, it appeared in tech support. OTA 1.0.4. But when I try to update
Hey folks, I posted a Synopsis of the X7 Mark II, for anyone interested: https://www.thesynops.com/fiio-x7-mark-ii-android-hifi-dap-synopsis/
What does this even mean?The stock amp doesn’t have a ton of power, so headphones that would benefit from more power may get a meatier sound.
Try volume matching properly next time you compare balanced and single-ended. The reason you think balanced is better is because without volume matching, the balanced is louder. You didn’t mention what gear you used with it - so very hard to tell. Sorry - just an honest opinion. I found it both inaccurate and lacking any real information.
+1Try volume matching properly next time you compare balanced and single-ended. The reason you think balanced is better is because without volume matching, the balanced is louder. Both use the same hardware, there is just two of everything. The difference in THD, SNR and other specs is below the audible range for humans. The only other difference may be slight frequency differences if you have very sensitive earphones like the Andromeda - but this is only limited to a small range of headphones. You didn’t mention what gear you used with it - so very hard to tell.
As far as the location of the power button goes, it was purposely placed on top after a lot of complaints that locating it on the side often caused people to accidentally hit the play pause or other buttons on the opposite side (this was a big issue wth both X7 and X5iii). Switching back to the side again (as you suggested) would be a regression.
You missed the obvious advantage (and difference from the X7) being the increase in RAM and it’s effect on the smoothness of the GUI.
For a review (or synopsis) that is supposed to be “tech synopsis for the informed” - I found it pretty lacking in detail, and full of vague references to tech which are questionable in their accuracy. There is also no disclaimer (is the review unit paid for or supplied by FiiO or someone else)? And some proper comparisons to DAPs in similar price ranges might be appropriate. How about real world tests with a variety of headphones / ear-phones?
Maybe I'm not getting it correctly, but this doesn’t seem very logical too...
On the bullet resume advantages/disadvantages: a Red Cross - Expensive, at $650 msrp
On conclusion: This is one of the best mobile audio players that we’ve heard and we feel it’s worth the price
In my understanding “Expensive” is a relative term, so, one or the other, right? Please don’t read this as one more guy throwing a stone, I appreciate the effort of the writing and thank the author for sharing it... criticism should always be understood as an opportunity for improvement, if we didn’t care we would just ignore it, IMHO.
In fairness, if he uses "expensive" to mean "costing a lot of money" rather than suggestions of "extortionate or exorbitant" then I have no problem with a buyer thinking it is worth its [high] asking price because of its prestige, quality, performance, or whatever.
But then it should not be listed as one of the disadvantages. Although the price discussion is subjective and relative, if it is worth the price, I don't count it towards disadvantages.In fairness, if he uses "expensive" to mean "costing a lot of money" rather than suggestions of "extortionate or exorbitant" then I have no problem with a buyer thinking it is worth its [high] asking price because of its prestige, quality, performance, or whatever.
