FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
179 180 181 182 183 184 185 186 187 188
190 191 192 193 194 195 196 197 198 199
  1. CarstenF
    Am I understanding you correctly that you are casting from the X7 II to the Chromecast Audio and going from there via optical out to the Mojo?
    If that is the case, it would be better to use the X7 II to play the music and go via coax out of the X7 to the coax in of the Mojo.
    Optical usually has worse timing than coax, especially if you are using the chromecast which has a worse clock than the X7 II. Also coax should be capable of 192 kHz.
  2. salla45
    - Yes for SQ , sure, but I like to use the X7II as a remote. :)
  3. FiiO
    Hi,
    May not. We don't have the cooperation with Hiby.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official http://www.fiio.net/fiio http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  4. Hawaiibadboy Contributor
  5. salla45
    @FiiO
    PLEASE consider putting a slot in the cases to allow easy access to the SD card slots. The USB acess is so slow as to be unusable (like 1-3mb/s transfer rate) and this means that one has to switch cards regularly when refining an OTG collection.
    I've had to butcher my silicone case to allow access :triportsad:
    Not ideal!
    What's notable is that I had to butcher the silicone case on my X3ii some 2 years ago when I got it! One would have thought one may have learned a little in the meantime??? :ksc75smile:
    Otherwise, a fantastic product. Really loving it :)
  6. Frida309
    For silikon case lokk at post No. 2404
  7. salla45
    I see, you have the same feelings! :) - let's hope they do consider it. There's no reason for this oversight in the design, especially as the X7ii's slots are protected with the trays from dust and such.
  8. salla45
    Hi,
    Does anyone know if it's possible to disable the lock screen on the X7ii?
    Thanks in advance for any reply :)
  9. Battlefier
    Am I the only how have the issue that sometimes the pause button a the left side of the X7 II does "next song" instead of pausing the current one playing?
  10. Dobrescu George
    Hey everyone!
    X7mkii is pretty lovely when using it at its full power!
    By the way, where is the latest firmware?
    Also, pic for love!
    X7mkii + Oriveti New Primacy!
    [​IMG]
  11. FiiO
    Hi,
    We will report this again to the engineers...
    Best regards
    salla45 likes this.
  12. FiiO
    Hi,
    You may set the sleep from settings--display to never for help?
    Best regards
  13. FiiO
    Hi,
    When playing in FiiO Music, right? Would it be a certain song?
    Best regards
  14. Battlefier
    Yes it happens when using Fiio music app and it doesn't seem to be on a specific song.
    However I forgot to mention that this bug appears occasionally and only when the device is locked (ie. the state after a short click on the power button).
  15. Paulo Abreu
    Lets see how this babies perform with X7 Mk2 ! :L3000:
    [​IMG]
    Hawaiibadboy and superuser1 like this.
