Matthew Davies
- Aug 31, 2016
Has anyone gotten "auto update" to work automatically? I sure have not.
Dear All,
Beta firmware version 3.0.2_beta for the X7(Android 5.1) now is available!
If your X7 is already FW3.0beta, pls try to update it by over-the-air automatic update (the WiFi on the X7 should be turned on firstly) or manual update via update zip file.
Here is the related update instruction for the above 2 methods: click here.
Update zip file for FW3.0.2_beta: https://www.dropbox.com/s/hr6wsb4jjy5nvcf/X7-3.0.2_beta-update.zip?dl=0
If you want to go back to the older version firmware, please click:
FW2.0 with flashing tool and instructions
FW1.91 with flashing tool and instructions
The following changes and improvements have been made to FW3.0.2_beta compared to FW3.0beta:
1. Added synchronized power on/off with K5;
2. Fixed the noise issue when playing some DTS WAV tracks;
3. Fixed issue where there's no sound output when playing some MP3/WAV/APE tracks;
4. Fixed issue where only the Power button would work in lockscreen with the Screen lock set to None;
5. Fixed issue where the volume buttons would not work when lockscreen is controlled by third-party music apps;
6. Fixed issue where the Adjustable volume at LO cannot be turned off when the X7 is connected to a docking station (The Adjustable volume at LO is now set to OFF by default);
7. Fixed issue where the file name/title sorting was in wrong order;
8. Fixed issue where the playback would not stop after all the tracks in one directory were played under Sequential play mode;
9. Fixed issue where there's no sound output when switching to DAC mode after exiting the music app;
10. Fixed issue where the play mode would be switched to Random automatically each time after opening FiiO Music and clicking to play;
11. Fixed issue where there's no sound output when a system prompt tone is played or after transferring files via Bluetooth;
12. Fixed issue where the Pulsar light setting would not take effect;
13. Fixed issue where the X7 would power on automatically after it's docked to DK1;
14. Improved the track search function (The Album and Artist info will also be displayed now);
15. Improved the file sorting (the song files and folders will be grouped separately now);
16. Improved the file name/track display problem of some tracks;
17. Fixed the issue where the player will freeze when switching to DAC mode sometimes;
18. Miscellaneous bug fixes;
Looking forward to everyone's feedback.
I cannot upgrade to the latest beta firmware.
I tried by copying the zip file to the internal storage and clicking on Firmware Update tool (in Technical Support), but I get an error message: "firm error"
I also tried through the device manager by following the instructions on this video:
https://www.dropbox.com/s/4ybisexjhcrf9fr/X7%20Firwmare%20Upgrade%20Instructions.mp4?dl=0
But there is no 'driver' folder in the update folder.
Firmware installed OK manually - OTA did not work. Most of my points about v3.01 remain in this version:
Track timing still not showing time left to end of track in FiiO Music
Search box background still too dark, unable to read clearly in FiiO music
192 KHz tracks down sampled to 96KHz playing from FiiO Music using Coax Out to Chord Hugo
Track details of track playing flickering while scrolling in FiiO music
X7 running much warmer than using FW v2.0. Suspect playtime will be reduced due to new FW, this is surprising since the X7 is not doing any amplification or DAC and is merely operating as a transport. will monitor closeley
Streaming tracks from Amazon Music is unreliable – downloading tracks works OK. Overall slightly better in this FW version but still not as good as FW v2.0
Unable to store music on external SD card downloaded from Amazon Music
SQ seems OK for me, however because of the down sampling I am unable to judge the SQ of Hi Res tracks - the down sampling is the biggest issue for me, however I am sure it will be solved. All tracks were played at the correct resolution in v2.0.
I'm going to stick with v3.02 for the moment to avoid the hassle of downgrading and then the need to carry our a double upgrade when the next version is released.
I guess you have already updated to v3.0.1? V3.0.2 will not run directly from FW v2.0 - took me a while to realize I hadn't read the instructions properly!
sorry , the rockchip have not provided burning kits for Mac OSX. I think it is not hard to find a window PC/notebook .
I don't know anyone with a PC anymore - I'd like to know you'll have this sorted out soon?
Library, internet cafe, lots of options for pc. Can't believe you don't have access to any pc.
Before going into this as a problem, if the creators of the code haven't made it possible to do the process from a MAC, it's not exactly Fiio's fault.
On the other hand, with a little free time, there are virtual machines as an option, and it can be done for free.
Yes of course
And that would be unbelievable - If I claimed there was no access to a pc. My comment was simply highlighting inconvenience for Mac users.
I think that until the end os this month we will receive the 3.0 firmware. One thing that I can say is: My Dunu DN2000 arrived last week, and I sold my Westone W4R. My AM5 amp arrived 3 days ago. Before it, I have installed the beta firmware. I bought the Mee Pinnacle P1 that will arrive next week. My Unique Melody Mentor is almost arriving too. I'm really impressive with the sound quality of the X7 + AM5 + Dunu DN2000!
