Dear All,
Beta firmware version
3.0.2_beta for the X7(Android 5.1) now is available!
If your X7 is already
FW3.0beta, pls try to update it by over-the-air automatic update (the WiFi on the X7 should be turned on firstly) or manual update via update zip file.
Here is the related update instruction for the above 2 methods:
click here.
Update zip file for FW3.0.2_beta:
https://www.dropbox.com/s/hr6wsb4jjy5nvcf/X7-3.0.2_beta-update.zip?dl=0
If you want to go back to
the older version firmware, please click:
FW2.0 with flashing tool and instructions
FW1.91 with flashing tool and instructions
The following changes and improvements have been made to FW3.0.2_beta compared to FW3.0beta:
1. Added synchronized power on/off with K5;
2. Fixed the noise issue when playing some DTS WAV tracks;
3. Fixed issue where there's no sound output when playing some MP3/WAV/APE tracks;
4. Fixed issue where only the Power button would work in lockscreen with the Screen lock set to None;
5. Fixed issue where the volume buttons would not work when lockscreen is controlled by third-party music apps;
6. Fixed issue where the Adjustable volume at LO cannot be turned off when the X7 is connected to a docking station (The Adjustable volume at LO is now set to OFF by default);
7. Fixed issue where the file name/title sorting was in wrong order;
8. Fixed issue where the playback would not stop after all the tracks in one directory were played under Sequential play mode;
9. Fixed issue where there's no sound output when switching to DAC mode after exiting the music app;
10. Fixed issue where the play mode would be switched to Random automatically each time after opening FiiO Music and clicking to play;
11. Fixed issue where there's no sound output when a system prompt tone is played or after transferring files via Bluetooth;
12. Fixed issue where the Pulsar light setting would not take effect;
13. Fixed issue where the X7 would power on automatically after it's docked to DK1;
14. Improved the track search function (The Album and Artist info will also be displayed now);
15. Improved the file sorting (the song files and folders will be grouped separately now);
16. Improved the file name/track display problem of some tracks;
17. Fixed the issue where the player will freeze when switching to DAC mode sometimes;
18. Miscellaneous bug fixes;
Looking forward to everyone's feedback.
