Paulo Abreu
Hi, I can only find an explanation on a faulty AM3, it's not the cable, same SE cable tested on AM2 & AM3, balanced cable with worst results on AM3.
Btw, last firmware 2.0?
My AM3 is dark, it's not the difference in S/N ratio specs that could explain this, and then, SE and balanced are the same
My 2 cents
Yes, it's 2.0 firmware.
I checked on another crappy iems which are not so bright. Noise is still present but much lesser than on FLCs. When connecting AKG 550 noise was inaudible. It seems that FLCs are very, very sensitive. I can't find any other explanation above that this is a faulty unit. Which I really want to believe it's not
Even so, FLC are 93 dB, my IEMs are 117 dB/mW and the background I can ear in several tracks is due only to the tracks themselves.
Maybe there is another explanation other than a faulty unit (doesn't seem to me too) ? Some of the techie members here may have a clue...
But the way you described it, it looks bad.
